Bilge Pump - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Bilge Pump
  1. ☑ ORIGINAL POSTER #1
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    SeaDoo's: 96 GTI 720, 95 XP 800 Limited, 96 GSX 787. 2000, 18' Bayliner 3.0L.
    Thumbs Up
    Received: 342 Given: 40
    Default Bilge Pump
    I've noticed over the last few days we've had a few cases of SeaDoo's partially sinking, or at least getting enough water in the hull to cause damage, in at least one case it looks like a motor replacement.
    Last weekend I made a bone head mistake and forgot to screw in one of the drain plugs, the bilge pump saved my a$$ that day. I have them in all my ski's. Bailers are marginal at best and do not work at all in no wake zones, or when docked.
    It's not expensive, about $65.00, and fairly easy to install. Cheap insurance.
    If there's any interest I will be happy to share how I installed and wired the bilge pumps.
    Lou
    Attached Images Attached Images
    "I would rather be lost at the lake than found at home."
    My reading of history convinces me that most bad government results from too much government.
    -Thomas Jefferson-
    I believe the best SOCIAL PROGRAM is a JOB!
    -Ronald Reagan-
    If I had Canadian soldiers, American technology, and British officers I could rule the world.
    -Winston Churchill-
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    It's a good idea. I have them in all my toys over the years. My big Polaris has a "Constant Duty" pump. It just turns on whenever the engine is running.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. #3
    Senior Member
    Join Date
    Oct 2011
    Location
    Edmond, Oklahoma
    Posts
    116
    Watercrafts
    1998 Speedster (2x787), 2003 GTX 4-tec Supercharged
    Thumbs Up
    Received: 1 Given: 1
    Default
    Im very interested in knowing how you have yours installed and tips. I will soon be installing one in my 03 GTX SC. Im thinking of connecting straight to the battery, with in-line fuse, so it will always be active without the lanyard and putting a switch on it for when trailered. Im debating between buzzer or strategically placing the outlet so I know if there is a major leak. In the buzzer solution I would wire in a float switch mounted at the same level as the top of the auto bilge pump, and tied to a buzzer. That way it only goes off if the bilge can't keep up. In the strategically placed solution i would place the outlet so i can either see/feel it spitting water and know when its running too often. This solution would require that I keep an eye on it though. Suggestions or thoughts?
    0 Not allowed!
  5. #4
    Member BIGTEX2010's Avatar
    Join Date
    May 2012
    Location
    Ottawa, Ontario
    Posts
    94
    Watercrafts
    1994 Seadoo SPX, 1994 Seadoo SPI
    Thumbs Up
    Received: 7 Given: 6
    Default
    I am also very interested in this ... also maybe we can use this thread as a place where people can show where they mounted their pumps and thru-hull fittings, and also show others how they have them switched.
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    Actually the installation is pretty straight forward. I used a Rule 500 PWC self sensing bilge pump. It senses for water every 60 seconds.
    http://www.amazon.com/Rule-PWC500-Au.../dp/B0000AZ6U8
    Pick a spot on the hull to locate the bilge pump, locate it low in the hull, I located mine near the bailers. I simply glued it to the hull with some locktite silicone seal, clean a spot on the hull with acetone before gluing the base to the hull.
    Wiring: I connected mine directly to the battery using a 3 amp fuse in the pos. line and I also wired a toggle switch (SPST) in the pos. line and locate the switch in a convenient place.
    For the discharge I went with function over form, as you can see on my 96GSX straight out the rear, and the 96GTI toward the rear (probably not the best place because it discharges into the footwell) I keep a piece of 1/2 heater hose and when I leave the ski over night I use the hose to discharge out the rear of the ski.
    The bilge pump in the XP was already installed and actually it discharges below the water line, I personally wouldn't have done it this way but as long as you loop the discharge hose above the water line it's O.K.
    A couple of notes, I installed the power switch in order to switch off the bilge pump when not in use, so as not to run the battery down. I checked around the internet and Rule now makes a small pump with an internal float, so it would only power on when there is water in the hull. This would make the switch optional. If I were doing it today I would use the bilge pump with the float, but I would probably still use the switch.
    http://www.amazon.com/Rule-25S-Autom...d_sim_sbs_sg_1
    You can get a kit with almost everything you need, pump, switch, wiring, discharge hose and thru hull fitting.
    That's about it, easy ain't it.
    Lou
    1 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    A couple more pictures.....
    Lou
    0 Not allowed!
  8. #7
    Join Date
    May 2012
    Location
    Ottawa, Ontario
    Posts
    94
    Watercrafts
    Thumbs Up
    Default
    Thanks for that reply Lou,
    I will be giving this a go at the end of the month for my skis ... I have the rule 360gph manual pumps though, do you think the smaller pumps will affect much? I only intend to use these as a last resort and my skis are never left in the water unless they are being used.
    0 Not allowed!
  9. #8
    SeadooForum Hall of fame Sportster-2001-951C-Stock's Avatar
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    6,899
    Watercrafts
    2001 Sportster LE 951 Carbed
    Thumbs Up
    Received: 284 Given: 47
    Default
    A+, Don't leave shore without it! Get one of those 45* angled thru-hull fittings, mount it just under the gunwhale and point that thing up so when the pump kicks on it shoots that water up onto the air.
    0 Not allowed!
  10. #9
    Junior Member
    Join Date
    Aug 2013
    Location
    atlanta
    Posts
    3
    Thumbs Up
    Received: 0 Given: 0
    Default
    Quote Originally Posted by LouDoo View Post
    Lou
    Lou,
    Thanks for the pictures... I'd like a little info on how to wire my Rule bilge pump to the battery. I have a Rule 460 GPH that has 2 wires coming out; one is brown and the other is black. I bought a kit that came with all the parts and instructions, but the wiring instructions seem more complicated than necessary. I'm installing on a 1995 GTX.
    Also would you recommend a rear discharge over a side wall?
    Thanks,
    Joe
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    It's actually fairly simple.
    Connect the black lead from the bilge pump either to directly to the neg. battery terminal or ground.
    Connect an inline fuse to the pos. battery terminal, use about a 3amp. fuse. The lead from the inline fuse goes to the SPST switch, connect the brown lead to the other terminal on the switch. Your done with the wiring.
    A rear discharge would be best but there's not a lot of room, so you will probably need to make the discharge in the side similar to my 96GTI.
    Lou
    0 Not allowed!
  12. #11
    SeadooForum Hall of fame bigJake's Avatar
    Join Date
    Jul 2008
    Location
    Pittsburgh, Pa
    Posts
    4,165
    Watercrafts
    96 GSX, 97 GSX, 01 Rinker Captiva 192
    Thumbs Up
    Received: 58 Given: 26
    Default
    Lou,
    I put 2 of them bilge pumps on my boat where the red circles are.
    A walk in the woods helps me relax and release tension.
    The fact that I am dragging a body should be totally irrelevant.
    24 hours in a day, 24 beers in a case. Coincidence? I think not.
    0 Not allowed!
  13. #12
    Junior Member
    Join Date
    Aug 2013
    Location
    atlanta
    Posts
    3
    Thumbs Up
    Default
    Lou
    Lou,
    Not to sound too stupid, how do you connect to the battery -- just wrap wires???
    Thanks,
    Joe
    0 Not allowed!
  14. ☑ ORIGINAL POSTER #13
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    Use a crimp on terminal.
    Lou
    0 Not allowed!
  15. #14
    Join Date
    Jul 2008
    Location
    Pittsburgh, Pa
    Posts
    4,165
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by jamica joe View Post
    Lou,
    Thanks,
    Joe
    Terminal connector Joe that fits the stud on the battery
    0 Not allowed!
  16. #15
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    6,899
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by bigJake View Post
    Lou,
    Hey, I recognize that boat from somewhere!
    http://abcnews.go.com/GMA/video/love...-yard-19913825
    And be sure to put a fuse on the positive as suggested above, fairly close to the battery terminal.
    Otherwise, if a short develops, you'll have red hot wires in your bilge, instantly!
    0 Not allowed!
  17. #16
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,117
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    Default
    Quote Originally Posted by Sportster-2001-951C-Stock View Post
    What happened on the Love boat stays on the Love boat.
    Unfortunately the Titanic suffered a different fate. I don't think even a Rule1,000,000 model would have helped it.
    For members in Michigan, please read the following thread & post your info.
    http://www.seadooforum.com/showthrea...-Michigan-Here
    If you wish to have your first name known to other members please sign up in this thread. http://www.seadooforum.com/showthrea...ht=#post313624
    To all Michigan boat owners, there is a new group in SDF called MICHIGAN WATERRIDERS. Click on Community at top of pg. & find Michigan Waterriders.
    "Beware of little expenses; a small leak will sink a great ship." ~ Benjamin Franklin
    0 Not allowed!
  18. #17
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    FLorida, Southern Area
    Posts
    13,835
    Watercrafts
    2009 RTX X (255 hp supercharged / inter-cooled). 2010 GTX 155
    Thumbs Up
    Received: 642 Given: 5
    Default
    Quote Originally Posted by Seadoobuddy View Post
    Softer metal or taller bulkheads would have saved the ship.
    Repairing iPhones and iPads. and Mini iPads Cracked screens, motherboards, speakers, home buttons ect ect,
    Screen replacements for iPhone and iPads. Discount to all forum members. Stocking refurbished iPhones and iPads..
    0 Not allowed!
  19. #18
    Join Date
    Jul 2008
    Location
    Pittsburgh, Pa
    Posts
    4,165
    Watercrafts
    Thumbs Up
    Default
    Loveboat? That's the Titanic matey.
    0 Not allowed!
  20. #19
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    Posts
    13,835
    Watercrafts
    Thumbs Up
    Default
    Lou
    The diaphragms in picture number two of post number 6 look to be of sufficient size to work for the pump...
    Just sayin...
    0 Not allowed!
  21. #20
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    6,899
    Watercrafts
    Thumbs Up
    Default
    Well, shiver me timbers!!!!!
    0 Not allowed!
  22. #21
    Member Slywun's Avatar
    Join Date
    Jul 2013
    Location
    Palm Coast/Saint Augustine Florida
    Posts
    31
    Watercrafts
    2013 Wake 155/2011 GTI130
    Thumbs Up
    Received: 4 Given: 0
    Default
    Greatly appreciate this post. After reading, I decided to give it a go. Did some research and contemplated several "pre-packaged" kits (from Seadoo and 'generic'). These kits were ranged from $90-$120.
    I ended up piecing together myself for around $75 which included:
    - 750gph pump with integrated float. I didn't really feel comfortable with a pure manual pump, or an automatic one that turned on at predetermined intervals. It is bigger than the Rule and other pumps.
    My pump came with a float dial that allows you to turn the float to to the pump on directly from the pump.
    - 3 way (manual/auto/off) switch w/10amp breaker. Really like the ability to turn on the pump or put it in auto mode and then turn off when storing. I installed in my GTI's glove box area - I don't believe it to impact storage too much.
    - Hose kit. I used about 1/2 of the provided hose. Came w a white outlet port and clamps. Was about $10.
    - Stainless steel outlet thingy (the above hose kit came w a white plastic outlet but I opted for stainless steel one, cost about $20, but probably could be found for cheaper. I just installed a speedtie kit so I put the outlet in the middle of the swim deck.
    Other items/incidentals.
    I'm admittedly a little OCD so it took my time and spread it over 2 days (total of 2 hours). I used liquid electrical tape on all if the electrical connections/terminals, and then shrink wrapped and bought 10ft of split wire loom to route the wires.
    The pump snaps on to a base which I epoxied to the engine bay floor. This allows you to remove the pump to clean our the pump inlet, etc.
    Works like a charm so far, and will be doing our Wake next week.
    Thanks again for the info, I hope I can assist a fellow member as this post has helped me.
    2 Not allowed!
  23. #22
    Senior Member Tytan's Avatar
    Join Date
    Jan 2014
    Location
    White Rock, B.C.
    Posts
    249
    Watercrafts
    2015 RXT-X 2005 GTX SC
    Thumbs Up
    Received: 24 Given: 1
    Default Whale 650 in an RXP
    Nice write up. I installed a Whale 650 in my RXP and will be installing another Whale in the GTX in the spring. All electrical connections are soldered with heat shrink, the switch is mounted in the glovebox with the power directly from the battery with an inline fuse. I put the discharge fitting next to the tow hook, I got a black fitting so it would blend in.
    2015 RXT-X The super couch.
    2005 GTX SC The couch.
    https://www.youtube.com/channel/UCcO...WrJI6RszgGnOnA
    1 Not allowed!
  24. #23
    Junior Member dtread's Avatar
    Join Date
    Apr 2012
    Location
    N.W Georgia
    Posts
    11
    Watercrafts
    1997 Seadoo GSX 2001 Kawasaki 900 STS
    Thumbs Up
    Received: 1 Given: 0
    Default
    Very nice write up! I am definitely going to put one in my LRV and my 97 GTX. My wife forgot to put in drain plugs last summer when she took it out with her family, partially sunk our 01 Kawasaki 900 STS. Then tried to fire it up and sucked water and killed motor.
    1 Not allowed!
  25. #24
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    Posts
    13,835
    Watercrafts
    Thumbs Up
    Default
    Nice write up and nice job installing it. I am also very anal and would have done the exact same thing in regards to the liquid tape and what not. Any in-line connections I always solder and then slide heat shrink over the soldered joint.
    Nice job...
    0 Not allowed!
  26. #25
    Join Date
    Jul 2013
    Location
    Posts
    31
    Watercrafts
    Thumbs Up
    Default Bilge Pump
    Thanks so much for the compliments. I would not have done without Loodoo and his original post.
    For our wake 155 however, we went w a different switch for the glovebox that allows you to select the fuse amperage.
    The original on our GTI uses a 10a breaker, too high for the pump, so I put in an inline fuse.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Bilge pump, nav lights, and bilge fan not working
    By Chuck3too3 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-14-12, 03:34 PM
  2. Bilge Pump !?!
    By SEA-MONSTER in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 03-20-11, 12:31 PM
  3. Bilge Pump-what is it & when do I use it?
    By Brosi247 in forum 4-Tec Sea-Doo Boats
    Last Post: 06-29-09, 12:42 PM
  4. 97 xp bilge pump
    By geo in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-01-08, 12:47 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
