1997 Seadoo XP blowing fuses - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Feb 2013
    Location
    Edmonton
    Posts
    20
    Thumbs Up
    Received: 0 Given: 0
    Default 1997 Seadoo XP blowing fuses
    A friend of mine put his battery in for the season backwards and tried to start it. Seadoo is a 1997 XP 800. After correcting the mistake he had blown the 15 amp fuse inside the black box and the 5 amp mpem fuse. After replacing the fuse it worked and started and drove for 10 minutes. It continues to blow fuses with varying lengths of run time. We have been reading about possible stator shorting and rectifier problems. The rectifier looks like it got hot in a couple places. We metered the mpem to test if there is a short in that fuse's circuit and it checks out fine. Does this sound like bad stator to anyone? or should we be looking into anything else.
    THanks
    0 Not allowed!
  2. # ADS
  3. #2
    Join Date
    Apr 2010
    Location
    TX
    Posts
    52
    Watercrafts
    2005 Seadoo Islandia 2003 Seado RXDI 2004 Polaris MSX
    Thumbs Up
    Received: 0 Given: 2
    Default
    I seen this happen alot man..check you vts motor first..then check stator for shorts to ground....but to tell you the truth.. everytime i had people come to me and told me that they put the battery backwards, the mpem will star blowing that 5amp fuse meaning that the diode inside mpem its bad now...check everything you can before you change mpem....unplug mpem and check for blow fuses....if you can get somebody to let you borrow their mpem try it...but am almost sure the mpem its not good no more
    0 Not allowed!
  4. #3
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    I would disconnected the regulator... and see if the problem goes away. If it does... replace it.
    You may have gotten lucky, and just blown the regulator.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. xp seadoo blowing 12amp fuses
    By zazzner in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-08-12, 04:32 AM
  2. 1997 GSX VTS blowing fuses
    By jjbyz4x4 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-22-09, 01:59 PM
  3. 96 Seadoo XP Blowing Trim Fuses?
    By d!face in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-17-09, 11:18 PM
  4. 97 SeaDoo GTI Blowing Front and Rear 15 amp fuses
    By gut2212 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-28-08, 06:42 PM
  5. 99 SeaDoo GTX keeps blowing fuses
    By beachblonde544z in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-19-08, 12:37 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
