Dess Post Problem?? - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 14 of 14
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Dec 2012
    Location
    Georgia
    Posts
    4
    Thumbs Up
    Received: 1 Given: 0
    Default Dess Post Problem??
    I was bringing my 96 XP out of winterization to start it so that I could sell it. When I put the key on, I got a single beep instead of the 2 quick beeps and it wouldnt start. After researching it, I found that the single beep was a "Wrong Key" code, but this is the only key I've ever had. I did get the double beep once though and tried to crank it but coulndt get it started. I sprayed a little starting fluid in the carbs, but then when I went to put the key on, I got the single beep again and havent been able to cranks it since. Since I got the double chirp once, do you think it's an issue with the DESS post only? Or do you think I have a problem with the key? I've cleaned both surfaces really well to no avail.
    1 Not allowed!
  2. # ADS
  3. #2
    SeadooForum Hall of fame Jetskigoodies's Avatar
    Join Date
    Feb 2012
    Location
    Michigan
    Posts
    2,983
    Watercrafts
    Almost every carb'd 787 and a couple 717's We have many used parts
    Thumbs Up
    Received: 144 Given: 49
    Default
    Clean all the connections in your rear box, clean the grounds well, check the fuses in the rear box, also check your ground, If it is your dess post i have a couple for sale. Just pm me if you need one
    0 Not allowed!
  4. #3
    Experienced Rider anthonygrato's Avatar
    Join Date
    Aug 2012
    Location
    Cape Cod MA.
    Posts
    368
    Watercrafts
    2 96 gtx's 1 HX 93 mako cuddy
    Thumbs Up
    Received: 0 Given: 6
    Default
    Did you check the battery? Connection on the battery?
    0 Not allowed!
  5. #4
    Minnetonka4me's Avatar
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,783
    Watercrafts
    3 Modded 96XPs -=- 93 GTX for the GF -=- and over 300 as parts for sale! -=-
    Thumbs Up
    Received: 174 Given: 275
    Default
    Its prob from the cold, but this is normally a post issue. Can be a key, but normally a post.
    Nick @ www.westsidepowersports.com -your Seadoo specialists!!
    Current part out list; Click below to view pictures. PM for availability & pricing
    Ride it like you ain't got a dime in it!!!
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Junior Member
    Join Date
    Dec 2012
    Location
    Georgia
    Posts
    4
    Thumbs Up
    Default
    Well, that didn't work. I installed the new dess post, I cleaned all the terminals in the back box, inspected the fuses, etc... all looked good. I put the key on and all I got was the one long beep instead of the two shorts. My understanding is that the one long beep is an indication that the computer thinks that the key is the incorrect one.
    Now what would you suggest?
    0 Not allowed!
  7. #6
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,783
    Watercrafts
    Thumbs Up
    Default
    Its time for a key. They typically dont go bad...but Ive had it happen once.
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Junior Member
    Join Date
    Dec 2012
    Location
    Georgia
    Posts
    4
    Thumbs Up
    Default
    Ugh... so what's the process to do that?
    0 Not allowed!
  9. #8
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,783
    Watercrafts
    Thumbs Up
    Default
    Take it to a dealer or someone who has a programmer. Most need the whole machine. If you have nothing close you can send your ebox or mpem to me and I can program one for you. See my other thread for pricing.
    Id recommend getting a replacement key vs. trying to reprogram the old key.
    0 Not allowed!
  10. #9
    SeadooForum Hall of fame nammer's Avatar
    Join Date
    May 2012
    Location
    St. Petersburg, Florida
    Posts
    2,833
    Watercrafts
    1979 Kawasaki JS440
    Thumbs Up
    Received: 12 Given: 9
    Default
    OP, glad you posted this problem, I tried working on my ski three days ago, was having the same exact problem on my 96 gsx, it happens intermittenly, when i get the 1 post, it won't try to start, when i get the 2 beeps, it's fine
    0 Not allowed!
  11. #10
    Join Date
    Feb 2012
    Location
    Michigan
    Posts
    2,983
    Watercrafts
    Thumbs Up
    Default
    I would suggest a brand new key as well, if you buy a new key from a dealer $45-$50 they will program it, but the charge for that is different dealer to dealer $25-$60
    0 Not allowed!
  12. #11
    Join Date
    May 2012
    Location
    Posts
    2,833
    Watercrafts
    1979 Kawasaki JS440
    Thumbs Up
    Default
    thanks jetskigoodies, yea i figured if i ever get it running if it gives me trouble i'll replace it, but it's a relatively new problem ever since i was playing with the electrical boxes up front
    0 Not allowed!
  13. ☑ ORIGINAL POSTER #12
    Junior Member
    Join Date
    Dec 2012
    Location
    Georgia
    Posts
    4
    Thumbs Up
    Default
    Is there a way they can test the key to see if it's lost it's code? I don't really trust this dealer as once I took two ski's in to get one serviced and when I picked it up, they removed the plug caps to the other ski. They also told me that i HAD to get a new key if I replaced the DESS post, which is simply untrue. They initially told me that I would probably need a new MPEM which would be anywhere between $800 - $2000
    0 Not allowed!
  14. #13
    Join Date
    Aug 2012
    Location
    Cape Cod MA.
    Posts
    368
    Watercrafts
    Thumbs Up
    Default
    find another dealer!!!
    0 Not allowed!
  15. #14
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,783
    Watercrafts
    Thumbs Up
    Default
    x2....gotta love stealerships.
    No...there isnt really a way to test the keys. The tool will tell me if a key is shot...I just had one that refused to register, grabbed another key and it programmed fine.
    The MPEM is what knows what keys it will accept; you can program up to 8 keys on one MPEM. Thats where Im a little lost on how a key would give the MPEM the wrong code, VS a bad key like mentioned above.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 1997 Seadoo XP - Key/DESS post problem
    By WakeSetter08 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-03-10, 08:37 PM
  2. Dess post
    By Tmac in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 05-26-09, 12:06 PM
  3. DESS Post from Ski Doo
    By cdnbikerdude in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-06-09, 03:20 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
