717 compression test - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 5 of 5
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Aug 2012
    Location
    Illinois
    Posts
    18
    Watercrafts
    Seadoo Sportster
    Thumbs Up
    Received: 2 Given: 0
    Default 717 compression test
    Just purchased a 717 remanufactured motor(not sbt). I installed the new motor and ran it for 5 mins with a pre-mix. After that, I did a quick compression test to see how the motor would fair. I was only getting about 138 on both cylinders.
    I was hoping for numbers in the 150+ range considering the motor is new. A mechanic told me that the engine will need to be broken in more and I should gain compression when everything has a chance to work itself in.
    Does this sound right or did I just get a weaker motor?
    Thoughts and thanks!
    0 Not allowed!
  2. # ADS
  3. #2
    SeadooForum Hall of fame El Toro 33809's Avatar
    Join Date
    May 2011
    Location
    Central Florida - Lakeland
    Posts
    2,009
    Watercrafts
    1996 Seadoo GTI 2001 Seadoo Challenger 2000 1996 Seadoo XP - project 2005 Aquatrax F12X 2003 Aqu
    Thumbs Up
    Received: 13 Given: 5
    Default
    If you have only run it for 5 minutes, the rings have probably not "seated". It sounds like what your mechanic told you is accurate. Test the compression again after the proper break in sequence.
    0 Not allowed!
  4. #3
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    If everything is absolutely perfect... it will show about 145 on a fresh engine. But... it's not uncommon for a brand new engine to need a little time before giving you a good compression number. Burn a couple tanks of fuel, and re-check.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Junior Member
    Join Date
    Aug 2012
    Location
    Illinois
    Posts
    18
    Watercrafts
    Seadoo Sportster
    Thumbs Up
    Default
    Sounds good! I will give it a proper break in and let everyone know what the new numbers are. Thanks for the feedback and the advice. It's really appreciated.
    0 Not allowed!
  6. #5
    Experienced Rider
    Join Date
    Jul 2011
    Location
    Vancouver
    Posts
    680
    Watercrafts
    18' Bowrider
    Thumbs Up
    Received: 21 Given: 9
    Default
    I had mine rebuilt and tested it after a few hours and had about 138 psi on both cylinders. Will test again once it is broken in. It seems to run really well with good power.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. compression test
    By esg in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 08-08-10, 08:50 AM
  2. last 2 ? about compression test
    By snosurfa7 in forum Non-Seadoo PWC Talk
    Last Post: 05-03-09, 08:55 AM
  3. Compression test ?
    By slowboatn in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-06-08, 08:18 PM
  4. How to do compression test?
    By bigJake in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-04-08, 11:36 PM
  5. Compression Test
    By laze in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-03-08, 12:18 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
