1998 GSX Limited Leaking? - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jun 2012
    Location
    Ohio
    Posts
    5
    Watercrafts
    1998 SeaDoo Gsx Limited 1997 SeaDoo Gtx
    Thumbs Up
    Received: 0 Given: 0
    Exclamation 1998 GSX Limited Leaking?
    Hey everyone, I was hoping to get some clarification on what might be wrong with my 1998 GSX limited ( i believe it is the 951 dual carb motor). I just bought this ski at the beginning of the year, and out of the water it is fine, but after i took it out last weekend, i noticed a white grease was on the inside of the hull. It seemed that it overall was the after mix of the marine oil. I noticed that it was all inside the hull after i realized water was leaking through the drain o-rings. So i was hoping someone might help me isolate where exactly this could be leaking from and how to fix this.
    So if anyone could inform me if this is common or any areas to check, I would greatly appreciate it !
    Please note that i am very new to jet skis and the placement of all the internals is new to me. I have worked all around car motors, but jet skis are a new thing, so please note that while explaining where i should check.
    Thank you!
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Unfortunately... there are not common leak areas. But... look at the grommets on the bottom of the oil tank, and the boot around where the drive shaft goes into the PTO.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jun 2012
    Location
    Ohio
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    Hi, Just want to update if anyone else has/have had this problem, it is the oil tank that is the two piece. It leaks at the seam ( also is leaking on my 1997 GTX ) To repair it, i just used some acetone around the seam and used some glue that was resistive to oil and it works like a charm! Good luck!
    0 Not allowed!
  5. #4
    Junior Member stitch626's Avatar
    Join Date
    Aug 2010
    Location
    EASTERN PA
    Posts
    18
    Watercrafts
    97 GTX seadoo
    Thumbs Up
    Default
    i have the same problem, what glue did you use? thanks
    0 Not allowed!
  6. #5
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,118
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    Default
    I had a similar leak, but very slow.
    It was the grommet on the bottom of the oil tank...the one with the 2 elbows. It was so loose that you could spin it easily, I bought a new one for about $6 and it's a nice tight fit, so no more leaking.
    For members in Michigan, please read the following thread & post your info.
    http://www.seadooforum.com/showthrea...-Michigan-Here
    If you wish to have your first name known to other members please sign up in this thread. http://www.seadooforum.com/showthrea...ht=#post313624
    To all Michigan boat owners, there is a new group in SDF called MICHIGAN WATERRIDERS. Click on Community at top of pg. & find Michigan Waterriders.
    "Beware of little expenses; a small leak will sink a great ship." ~ Benjamin Franklin
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Junior Member
    Join Date
    Jun 2012
    Location
    Ohio
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    I used "SEALALL" glue, it's like $6 a bottle or something like that, i just bought a pair of gloves and right around the seam just put on the glue, it takes a few minutes to settle, and 6 hours to cure. It worked really well though, Make sure you use a lot though!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Driveshaft leaking 98 GSX Limited
    By bthacker in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-19-11, 04:47 PM
  2. 1998 and 2000 gti leaking water into head
    By killer71 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 06-08-10, 12:37 PM
  3. 1998 gsx limited
    By slobra300 in forum 2-Stroke Performance Forum
    Last Post: 08-18-09, 01:44 PM
  4. 1998 GTX Limited
    By 98 GTX Limited in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 10-03-08, 11:56 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
