Exhaust Gas Temp Sensor Replacement - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Results 1 to 7 of 7
  1. ☑ ORIGINAL POSTER #1
    Member dothadoo's Avatar
    Join Date
    May 2011
    Location
    Alabama
    Posts
    86
    Watercrafts
    2007 Speedster 150, SC
    Thumbs Up
    Received: 0 Given: 0
    Default Exhaust Gas Temp Sensor Replacement
    In searching the part number for the Bosch 0280130093 Coolant Temperature Sensor, I have found a few places that have them for around $10 on the net. The thing is that they do not offer any pictures to ensure that is exactly what I need. I have called my local Auto Parts places and they have another brand, Borg Warner, pt#: WT3069, which does have the picture and it looks pretty dang close to what I need, for around $25. This particular sensor is very generic and used on several types of cars too, come to find out.
    Has anyone else tried another brand besides going through someone who sells Sea Doo parts only? The dealership wants about $80 and I believe I have seen somewhere on here where people have bought them for around $65 from Sea Doo Parts Warehouse or somewhere like that.
    Here is the Advanced Auto Parts solution.
    http://shop.advanceautoparts.com/web...10944&ci_sku=#
    0 Not allowed!
  2. # ADS
  3. ☑ ORIGINAL POSTER #2
    Join Date
    May 2011
    Location
    Alabama
    Posts
    86
    Watercrafts
    Thumbs Up
    Default
    I just bought the Borg Warner, or Import Direct temp sensor today and it looks identical to the Bosch version with the exception to the inside of the plastic connector. The stock one has grooves on one side while the offbrand has grooves on one side. This however, should not effect how the connector should hook up. I will put it in this weekend and see how it works.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    May 2011
    Location
    Alabama
    Posts
    86
    Watercrafts
    Thumbs Up
    Default
    Okay, so I had both the OEM gas temp sensor, $81 from the local dealer, and also decided to go to my local O'Reilly Auto Parts store and get the brand they carried. I ended up with an Import Direct brand, part number 17-1211 for $26. I replaced the old one, which was black, indicating it had gotten too hot, and replaced it with the Import Direct brand. I have to say that I was a little apprehensive, but after riding around slowly at first then WOT, no code came back up and all seems to be well for the moment. I was also able to return my original $81 OEM part back to the dealer with no questions asked. I hope this will help someone else out the next time they go to replace the exhaust gas temp sensor.
    0 Not allowed!
  5. #4
    Junior Member JamesHill's Avatar
    Join Date
    Jun 2012
    Location
    1713 Trinidad Ave NE, Washington, DC 20002
    Posts
    2
    Watercrafts
    Do not want to share
    Thumbs Up
    Thumbs up
    All the post of this thread is so good. If you want to do P0546 Exhaust Gas Temperature Sensor Circuit Malfunction then this code happens most often when you replace with catalytic-convert up pipe with a catless up pipe. The result is that the EGT sensor that goes in that pipe is exposed to a blast of flaming exhaust gas, and eventually burns out. Replace the bad EGT sensor, and the new one will probably burn out as well.
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Join Date
    May 2011
    Location
    Alabama
    Posts
    86
    Watercrafts
    Thumbs Up
    Default
    Mine was a result of starting the boat out of the water. I only ran it for about 10 secs or so, but apparently that was enough to fry it.
    0 Not allowed!
  7. #6
    Experienced Rider devonte007's Avatar
    Join Date
    Jan 2010
    Location
    chicago, IL, SW Michigan
    Posts
    427
    Watercrafts
    2004 Seadoo Sportster 4-tec 155hp
    Thumbs Up
    Received: 48 Given: 2
    Default
    Thanks for the tip and for posting, I'll definitely keep it in the library in case I ever run into this same problem in the future!
    0 Not allowed!
  8. #7
    Junior Member
    Join Date
    Sep 2012
    Location
    Florida
    Posts
    1
    Watercrafts
    2006 Sea Doo GTI SE
    Thumbs Up
    Default
    I tried the same thing for my 2006 Seadoo GTI SE. Worked in the driveway with the water running. Will try it on the water later today/tomorrow.
    If it works, what a cheap fix...less than $24 at Advance Auto.
    Thanks!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 08 215 SCIC Exhaust Temp Sensor
    By Scott0321 in forum 4-Tec Sea-Doo Boats
    Last Post: 05-07-11, 09:05 PM
  2. Temp Sensor Bad? GTX 95
    By Underwater78 in forum 2-Stroke Performance Forum
    Last Post: 08-15-10, 09:15 PM
  3. Exhaust Gas Temp Sensor - Code PO544
    By Kaj in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-07-08, 01:52 PM
  4. Temp. Sensor
    By speedster4us in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-21-08, 01:45 AM
  5. temp sensor
    By nursetracib in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-03-08, 01:45 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
