Rotary valve 787 Questions - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
  1. ☑ ORIGINAL POSTER #1
    Junior Member moto17's Avatar
    Join Date
    Jul 2009
    Location
    ny
    Posts
    17
    Watercrafts
    900 gtx 03 challenger 180 97
    Thumbs Up
    Received: 0 Given: 0
    Default Rotary valve 787 Questions
    I just put in an new SBT 787 in my (1997 Challenger with one 787) jet boat and new carbs as well! Sooo the timing seems to be still off....I learned how to do it on this site and put in a new rotary valve form WSM ? hmmm it wont line up exactly right? it seems to be off just a little bit. The new motor turned over hard but I got it to start,timing is still off!. Has anyone tried a Carbon Tech rotary valve with any luck? and how about trying a different pitch?The one for my boat is a 159 might a 163 work as well? or would it need to be used with a hi performance pipe? I would like more power... any ideas ? Thank you
    0 Not allowed!
  2. # ADS
  3. #2
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,118
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    0 out of 1 members found this post helpful.
    Default
    Try flipping the rotary valve over and see if it lines up better than before. Make sure you have the right one also.
    For members in Michigan, please read the following thread & post your info.
    http://www.seadooforum.com/showthrea...-Michigan-Here
    If you wish to have your first name known to other members please sign up in this thread. http://www.seadooforum.com/showthrea...ht=#post313624
    To all Michigan boat owners, there is a new group in SDF called MICHIGAN WATERRIDERS. Click on Community at top of pg. & find Michigan Waterriders.
    "Beware of little expenses; a small leak will sink a great ship." ~ Benjamin Franklin
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Jul 2009
    Location
    ny
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    yea I tried that but no better! wondering if anyone has tried a Carbon Tech one?
    0 Not allowed!
  5. #4
    Chester's Avatar
    Join Date
    Nov 2008
    Location
    Surrey, BC Canada
    Posts
    1,198
    Watercrafts
    98 SXi Pro
    Thumbs Up
    Received: 7 Given: 4
    Default
    Stay away from any carbon fiber rotary valves. They will quickly wear out the surfaces on the RV cover and the cases.
    It doesn't have to be exact. The valve opening spec is 147* plus or minus 5*. You should be able to flip it over to get it within 5 degrees of 147*. The valve is asymmetrical.
    Chester
    "A smooth sea never made a skillful mariner."
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Join Date
    Jul 2009
    Location
    ny
    Posts
    17
    Watercrafts
    Thumbs Up
    Default
    We tried for an hour! the WSM one is a exact copy on the outside but the teeth are not the same.This makes it come out about %7 off any way you turn it.
    I have a WSM dealership and just got off the phone with them,I ordered a Carbon Tech one as it is stamped different. They will take the other one back! I will pick up a oem Seadoo one or get one from SBT that is stainless. Thank you Chester I will have to check it in a few weeks! But I will have a backup!
    0 Not allowed!
  7. #6
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Yep... like Chester said... get rid of the carbon valve. They don't last... and they wear out the cases. It's truly a product that shouldn't be made.
    Get a factory 159 degree valve, and put it in.
    One thing though..... Since you said you have "New carbs"... did you verify what's inside? (Jet's and pop-off) Also... are they the same size?
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. rotary valve
    By bluefunk in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-01-10, 03:03 PM
  2. What is the best way to set the rotary valve
    By brewersmotorsports in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-28-10, 05:11 AM
  3. Rotary valve on 717
    By Bills86e in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-09-09, 12:15 AM
  4. 98 xp ltd 947 rotary valve
    By caper in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-24-08, 10:37 AM
  5. rotary valve
    By jake2323 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-01-08, 05:03 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
