1997 GSI issues HELP!!!!! - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 7 of 7
  1. ☑ ORIGINAL POSTER #1
    Junior Member Matt4469's Avatar
    Join Date
    Jun 2012
    Location
    Charleston, wv
    Posts
    29
    Watercrafts
    1997 seadoo gsi
    Thumbs Up
    Received: 0 Given: 0
    Default 1997 GSI issues HELP!!!!!
    Gents, I have a 97 GSI with trim. I got the ski yesterday and brought it home. I hooked the battery up. When I did that the gauge and light came on and stays on for as long as the battery is connected. Ive tried taking the key off and on, hitting the start button x5. I'm am new to jet skis but pretty mechanically inclined. I've checked all the elect. Boxes, no water in them. Any help would be appreiciated!
    0 Not allowed!
  2. # ADS
  3. ☑ ORIGINAL POSTER #2
    Join Date
    Jun 2012
    Location
    Charleston, wv
    Posts
    29
    Watercrafts
    1997 seadoo gsi
    Thumbs Up
    Default
    Also from what I can find, all of the fuses are good... I've found 2 15a, 1-7.5a and 1-5a..
    0 Not allowed!
  4. #3
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Are you getting beeps when you put the lanyard on? Does it start and run?
    The MPEM controls the power... so if it's staying on... either someone was playing with the wiring... or the MPEM is bad.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Join Date
    Jun 2012
    Location
    Charleston, wv
    Posts
    29
    Watercrafts
    1997 seadoo gsi
    Thumbs Up
    Default
    thanks for the response Dr Honda.. I am getting no beeps and it will not start by the start button... How would I go about checking the MPEM? (im guessing thats the computer??) Also, when I bought it they guys was saying that the 5a fuse kept blowing... however when I brought it home, i discovered one of the plugs going into the computer was loose. I secured it and it quit popping the fuse..
    0 Not allowed!
  6. #5
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    Thumbs Up
    Default
    5a fuse is blowing................. Yep............ the MPEM is done. (yes, that's the computer)
    Basically... there is a protector diode in the MPEM, and when it shorts/blows... it will take out the 5a fuse. (continuously) Some times you can cut open the MPEM, and replace the diode... but in this case, it sounds like someone hooked up a battery backward, and really blew it.
    Not to be harsh... but I hope you didn't pay too much for it, because an MPEM isn't cheap. AND... knowing that is bad... there could be other issues.
    ****EDIT****
    looks like your MPEM is around $525. (not a common unit) P/N 278000928
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Jun 2012
    Location
    Charleston, wv
    Posts
    29
    Watercrafts
    1997 seadoo gsi
    Thumbs Up
    Default
    the fuse isnt blowing anymore...... would you still suggest that the MPEM is still trashed? I only paid $100 for the ski so its not so bad...
    The gauges stay on almost like if you were in a car and once you turn the ignition all the gauges shoot to the top.... every single light stays on.....
    also i told you wrong it is the 7.5 fuse that is blowing..
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Jun 2012
    Location
    Charleston, wv
    Posts
    29
    Watercrafts
    1997 seadoo gsi
    Thumbs Up
    Default
    Ok just did some shooting, all of the fuses are good and no longer blowing.... I can crank the motor by the solenoid and it sounds good.... The thing is the gauge panel still stays lit up all the time.
    Is there a way to "hot wire" it to make it start up? I want to make sure it runs before I go dumping money in it... As always thanks for the help!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 1997 gsi issues
    By Matt4469 in forum Meet and Greet
    Last Post: 06-09-12, 11:13 AM
  2. 1997 sea doo gtx motor issues
    By trabich in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-06-09, 07:54 PM
  3. 1997 GTX few Issues need help with
    By deerehauler in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-20-09, 08:05 PM
  4. 1997 GTX Starting Issues
    By nissanracer007 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-11-09, 12:57 PM
  5. 1997 GTX Issues
    By SLIMCAT in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-09-08, 09:56 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
