Keeping carb clean - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 23 of 23
  1. ☑ ORIGINAL POSTER #1
    Member nickelz's Avatar
    Join Date
    May 2012
    Location
    Buffalo NY
    Posts
    49
    Watercrafts
    1998 XP Limited 951 2010 RXt-X
    Thumbs Up
    Received: 0 Given: 0
    Default Keeping carb clean
    Are there any additives that i can add to the oil or fuel to keep my carb tiptop. All opinions and help i would really appreciate. Its a 98 xpl 951. Thanks
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Fuel stabilizer will help... but nothing will correct previous years of neglect. Regardless... carbs are a mechanical device... and eventually they will need serviced.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    May 2012
    Location
    Buffalo NY
    Posts
    49
    Watercrafts
    Thumbs Up
    Default
    Yeah i kinda figured that lol. I cleaned it 4 years ago. Always run 91octane. Always use stabil marine formula in every fill up. Thanks
    0 Not allowed!
  5. #4
    SeadooForum Hall of fame Spimothy Leary's Avatar
    Join Date
    Apr 2010
    Location
    SW Florida
    Posts
    7,519
    Watercrafts
    2008 RXTX
    Thumbs Up
    Received: 205 Given: 32
    Default
    never used stabil but I think it depends on how frequently you ride, when i'm running i ride weekly so my fuel never sits long.
    0 Not allowed!
  6. #5
    Join Date
    May 2012
    Location
    Chicago (Chain O' Lakes)
    Posts
    33
    Watercrafts
    1994 Sea-Doo SPX 1993 Sea-Doo XP
    Thumbs Up
    Default
    somepeople really like seafoam, some dont. some people really like juist a regualr carb cleaner additive put into your gas. it really depends on the person. i myself, just add carb cleaner before the carb gets too bad. aroun donce every year. but again, different people will say different things. but like Doc said, carbs will need servicing eventually.
    0 Not allowed!
  7. #6
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Wardkid View Post
    NEVER... in a 2-stroke !!!! It can kill the engine.
    0 Not allowed!
  8. #7
    Join Date
    May 2012
    Location
    Posts
    33
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Dr Honda View Post
    Like I said you either love seafoam or hate it
    P.s. I personally don't use seafoam
    0 Not allowed!
  9. #8
    SeadooForum Hall of fame mikidymac's Avatar
    Join Date
    May 2012
    Location
    California
    Posts
    3,637
    Watercrafts
    2003 GTI 1996 XP 2001 XP 1996 HX
    Thumbs Up
    Received: 158 Given: 4
    1 out of 1 members found this post helpful.
    Default
    I think what Dr. Honda was saying that any of these "Carb Cleaners" including sea faom are a cleaner and are designed to remove varnish and deposits from the fuel system. These are for our purposes a solvent and when they remove varnish and deposits in a 2 stroke they can remove the little bit of oil film that is in the fuel/oil mix as the fuel/oil/carb cleaner mix reaches the crank and cylinders unlike a 4 stroke. There goes your crank and piston lubrication. Remember that there is actually very little oil in these engines so anything that is removing/cleaning that oil film can lead catastrophic failure. Much like a$@ holes we all have an opinion so use at your own risk. I prefer regular Sta-Bil for storage but if we had ethanol here I would probably use their marind formula.
    0 Not allowed!
  10. #9
    Join Date
    May 2012
    Location
    Posts
    33
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by mikidymac View Post
    Wow... Thanks! Real helpful post! Now that you say that it really does all make sense. Does anyone know of any let's say ( 2-stroke safe carb cleaners?)
    0 Not allowed!
  11. #10
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    no !
    Anything that can clean... can destroy the oil. (assuming you are looking for a pour-in band-aid)
    mikidymac: Thanks... I've typed that about 50 times this spring.
    0 Not allowed!
  12. #11
    Join Date
    May 2012
    Location
    Posts
    33
    Watercrafts
    Thumbs Up
    Default
    Thans Doc! I appreciate it!
    0 Not allowed!
  13. #12
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    SeaDoo's: 96 GTI 720, 95 XP 800 Limited, 96 GSX 787. 2000, 18' Bayliner 3.0L.
    Thumbs Up
    Received: 342 Given: 40
    Default
    Tony when I saw the comment about Seafoam I could see the hair stand up on the back of your neck all the way from Kentucky.
    I did want to make a comment about carbs., I re-did the carbs. on my 96GTI last winter, it's the first time they had ever been cracked. I did check the carb. filters when I replaced the fuel lines a couple of years ago, and except for being dirty there was no green goo, they were in good shape.
    The carbs. were in great shape very clean the ski has relatively low hours and most of the gas purchased was at the marina, no alcohol, I did re-build them but I was amazed how little they needed after 16 years.
    Maybe Harry Trumann was correct, "if it ain't broke don't fix it."
    Lou
    "I would rather be lost at the lake than found at home."
    My reading of history convinces me that most bad government results from too much government.
    -Thomas Jefferson-
    I believe the best SOCIAL PROGRAM is a JOB!
    -Ronald Reagan-
    If I had Canadian soldiers, American technology, and British officers I could rule the world.
    -Winston Churchill-
    0 Not allowed!
  14. #13
    SeadooForum Hall of fame SabrToothSqrl's Avatar
    Join Date
    May 2009
    Location
    PA
    Posts
    5,426
    Watercrafts
    2002 GTX & XP
    Thumbs Up
    Received: 163 Given: 2
    Default
    I imagine you can use carb cleaner, when the carbs are OFF the engine... then it will dry and not get into the block, correct?
    0 Not allowed!
  15. #14
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by SabrToothSqrl View Post
    Well... that's totally different.
    When they are off... yes... you need a solvent of some kind to clean them. BUT... you can't run it though the carbs, with the fuel.
    0 Not allowed!
  16. #15
    SeadooForum Pro crisso's Avatar
    Join Date
    Jan 2010
    Location
    Gold Coast Australia
    Posts
    1,543
    Watercrafts
    Dec.1998 GTX Limited 1750 Bullet200 merc 32 carvel hull trawler.Spotted gum.11.1 ton 2012 GTI 130
    Thumbs Up
    Received: 6 Given: 0
    Default
    Was that question really asked!!
    Why is it,that when you are driving and looking for an address,You turn down the volume on the radio?
    0 Not allowed!
  17. #16
    SeadooForum Pro RodInEscondido's Avatar
    Join Date
    Sep 2011
    Location
    Escondido, CA
    Posts
    1,049
    Watercrafts
    2000 GTS 98 GTS 96 XP 94 GTS 91 SP 90 SP 89 SP 77 SeaRay Sundancer 25
    Thumbs Up
    Received: 38 Given: 6
    Default
    Doc, seems I recall you making an observation in another thread about how crappy the new carb cleaners are. Were you speaking of the aerosol cans or the gallon cans into which you soak the carb/parts or something totally different?
    thanks,
    Rod
    age and treachery will overcome youth and skill
    0 Not allowed!
  18. #17
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by RodInEscondido View Post
    thanks,
    Rod
    That would be the parts dip. (in the gallon can)
    In my shop, all I use is carb spray, and compressed air to clean the carbs.
    0 Not allowed!
  19. #18
    Join Date
    Jun 2012
    Location
    virginia beach
    Posts
    40
    Watercrafts
    1996 Seadoo GTX
    Thumbs Up
    Default
    (digging up an old thread here)
    So, Dr. Honda, you don't recommend using any fuel additives? I put high grade fuel in my Ski and having just re-built the carbs want to make sure I keep them as clean as I can (one was almost completely gooped up from the previous owner - though I suppose that may have been from the gray fuel lines which have now been replaced). Either way, how do you recommend keeping it clean and combating the ethanol?
    0 Not allowed!
  20. #19
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    If you don't mind I'll step in here, because I've been around for a while and I know what the Doc's answer will be. Marine Stabil, nothing else.
    Lou
    0 Not allowed!
  21. #20
    Senior Member
    Join Date
    May 2012
    Location
    indiana
    Posts
    183
    Watercrafts
    1996 sea doo gtx
    Thumbs Up
    Default
    What do you say about a product like Mercury Quickleen. Good, bad, or indifferent in these engines??
    0 Not allowed!
  22. #21
    Join Date
    Jun 2012
    Location
    virginia beach
    Posts
    40
    Watercrafts
    1996 Seadoo GTX
    Thumbs Up
    Default
    Quote Originally Posted by LouDoo View Post
    Lou
    after I posted that I found some other older threads explaining how since SeaFoam is a solvent it's not wise to use it in a 2-stroke. Pretty much answered my question. Seems like it's 50/50 on whether or not to use SeaFoam. If you all say not to, I'm fine with it. Just want to make sure the carbs stay clean. The guy at the local Seadoo dealership was trying to sell me some Seadoo Carb Spray/Cleaner? Is this a good idea?
    0 Not allowed!
  23. #22
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by riding high View Post
    Quicksilver Quickcare might be O.K., as it's a competitive product to Marine Stabil, Quickleen definitely not. As long as it's readily available I'm sticking with Marine Stabil.
    Lou
    0 Not allowed!
  24. #23
    Join Date
    Jun 2012
    Location
    Toronto,Canada
    Posts
    72
    Watercrafts
    1995xp,Nordic 1710,Bayliner Bass Trophy
    Thumbs Up
    Received: 2 Given: 0
    Default
    I've been using Seafoam in my outboard for years,and know lots of others who do the same.None of us have had any problems with it.If you look at the MSDS for it you'll find that there is alot of pale oil in it for lube.
    I was also wondering if it was safe to use in a 1995 XP.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Anyone near Clarksville/Nashville TN that can help on carb clean/rebuild?
    By jabroni1m in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 03-07-12, 11:10 PM
  2. Oily Carb and Exhaust - know the source but need clean up help
    By mlangford in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-13-10, 08:25 AM
  3. Carb clean Needle & seat
    By wutagoalie in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-27-10, 03:59 PM
  4. Clean carb filter
    By Billa in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-18-08, 10:36 PM
  5. 94XP Carb clean out
    By Fields in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-09-08, 11:16 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
