Convert DI to CARB - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 8 of 8
  1. ☑ ORIGINAL POSTER #1
    SeadooForum Hall of fame SabrToothSqrl's Avatar
    Join Date
    May 2009
    Location
    PA
    Posts
    5,421
    Watercrafts
    2002 GTX & XP
    Thumbs Up
    Received: 162 Given: 2
    Default Convert DI to CARB
    Has anyone converted a DI ski to CARB rather than fixing it?
    are the engines similar enough?
    I'm looking for a 01 RX Carb and can only find the DI ones...
    can you just remove all that stuff and it would work (adding carbs obviously) or is it too different?
    Just curious...
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Can't say I've heard of anyone doing it... but I'm sure it's possible. BUT... remember... you will need a new MEPM also, since that one thinks it's controlling a fuel injection system.
    I guess if I was going to do it... I would buy a stand-alone ignition system to make it easy, and ditch the MPEM.
    BUT... if you buy a Di ski... why not just run it that way until there is a problem?? They are very reliable... it's just hard/expensive to fix once they have an issue.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. #3
    Join Date
    Aug 2011
    Location
    Posts
    2,287
    Thumbs Up
    Received: 65 Given: 21
    Default
    a friend of mine, wanted to do this, but the engines are different, (injectors), 1 has a 5 port sleeve - di -- and carb eng i believe has a 6 port sleeve
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Join Date
    May 2009
    Location
    PA
    Posts
    5,421
    Watercrafts
    2002 GTX & XP
    Thumbs Up
    Default
    even if the MPEM thinks it's controlling the injectors, and you remove them...? I guess it would throw an error code?
    No, I agree, if it works, run it until otherwise, I've just never had a DI ski, I've ridden them, they seem quieter, and accelerate very smoothly, and start easily! I just worry about expensive repairs...
    0 Not allowed!
  6. #5
    Join Date
    Nov 2007
    Location
    cape coral fl
    Posts
    1,762
    Watercrafts
    (2) 2003 GTX 4TEC
    Thumbs Up
    Received: 12 Given: 1
    Default
    Grizz is correct. Engines (cylinders, head, etc.) are different.
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    May 2009
    Location
    PA
    Posts
    5,421
    Watercrafts
    2002 GTX & XP
    Thumbs Up
    Default
    what if I have a spare 951 sitting in my basement? (carb)... lol (which, yes, I do)
    0 Not allowed!
  8. #7
    Junior Member
    Join Date
    Jun 2011
    Location
    NE Indiana
    Posts
    19
    Watercrafts
    1999 Sea-Doo GSX Limited 2001 Sea-Doo RX-DI 2007 Sea-Doo RXP 215
    Thumbs Up
    Received: 0 Given: 0
    Default
    how many hours are on the rxdi's that you are looking at? I have almost 200 hours on mine and have never had a problem with the DI. Also it gets better fuel milage than my gsx limited (carb) that also has the 951.
    0 Not allowed!
  9. #8
    Experienced Rider - BiRkS_'s Avatar
    Join Date
    Mar 2010
    Location
    Mississauga, Ontario
    Posts
    883
    Watercrafts
    '91 GT 587 '97 gsx 787 '98 xp 951 ltd 2000 GTX M/E 951 (sold)
    Thumbs Up
    Received: 40 Given: 1
    Default
    If you wanted to trick the computer... measure the resistance on a known good injector, then replace the injector with the equivilant resistor. I have little experience with the 951 or DI but i dont think a different head would affect much...if you have the parts, it may be an interesting conversion for a rainy day. And if it doesnt work, just swap it back to DI
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Convert premix
    By stevenf in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-18-11, 10:50 AM
  2. How do I Convert My 93 XP to Premix?
    By djwill_7 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-27-09, 10:33 AM
  3. 1998 717 GS convert to pre-mix
    By gkm24 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 12-08-08, 05:00 AM
  4. Replies: 12
    Last Post: 07-15-08, 06:43 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
