Does anyone have pictures on intercooler winterizing on supercharged 4 tec? - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 11 of 11
  1. ☑ ORIGINAL POSTER #1
    Senior Member andrew224's Avatar
    Join Date
    Jun 2011
    Location
    lake norman
    Posts
    100
    Watercrafts
    2011 sea doo GTI SE 155 1997 gsx
    Thumbs Up
    Received: 0 Given: 0
    Default Does anyone have pictures on intercooler winterizing on supercharged 4 tec?
    ?????????????? looking for pictures about how what hoses to pour af into on a supercharger 4 tec.
    0 Not allowed!
  2. # ADS
  3. ☑ ORIGINAL POSTER #2
    Join Date
    Jun 2011
    Location
    lake norman
    Posts
    100
    Watercrafts
    Thumbs Up
    Default
    helped a friend winterize his 05 rxt, pulled hoses off supercharger in the front of the engine , and no water came out , drained exhaust manifold a few drops came out, pour about 10 oz of af into manifold which is pretty straight forward. as the manual states install bottom hose on supercharger and pour about 8 oz of af , we did exactly that took fill hose off and af ran out of fitting, so we put the top hose back on supercharger and pour some more af into bottom fitting of sc, took fill hose off and not much came out. the bottom fitting of the sc says in and the top sc fitting says out . did we do this correctly?
    0 Not allowed!
  4. #3
    SeadooForum Pro ski-d00's Avatar
    Join Date
    Apr 2009
    Location
    St. Marys, Ohio
    Posts
    1,909
    Watercrafts
    2012 RXPX 2012 GTR 215 2006 3D DI 2005 Speedster 200 SC 370HP
    Thumbs Up
    Received: 69 Given: 1
    Default
    not really, here is what the service manual states and the interpretation in parenthesis...
    – Remove both intercooler hoses. (at the ic, both upper and lower)
    - Let the intercooler drain, then connect the bottom
    hose. (not much will come out)
    – Pour approximately 200 mL (6.76 oz U.S.) of
    antifreeze into the intercooler. (they forget to tell you to get a short piece of same size hose connected to a funnel and connect the other end to the top side of the ic and pour in the top side of the ic which is actually the exit side under normal operation)
    – Then pour approximately 300 mL (10.14 oz U.S.)
    of antifreeze into the exhaust manifold.(they forget to tell you the upper hose of the ic goes to the exhaust manifold and just attach your funnel to this upper hose of the ic and pour in here.
    – Reconnect the upper hose.
    So, basically, you are just disconnecting one hose and pouring in both sides of it, make sense? the manual is not clear at all, I'll give you that.
    0 Not allowed!
  5. #4
    SeadooForum Pro Michael211_2000's Avatar
    Join Date
    Sep 2010
    Location
    Splendora, Texas
    Posts
    1,312
    Watercrafts
    1975 Sidewinder of Wisconsin (jetboat) 2006 Seadoo RXT (PWC)
    Thumbs Up
    Received: 7 Given: 10
    2 out of 2 members found this post helpful.
    Default
    Simpler to just pump it full of pink RV antifreeze (available at Academy) till pink water starts pouring out the exhaust. I use a cheapo on/off bilge pump with a 5 foot piece of waterhose fitted to it.
    Submerge the pump in pink anti-freeze (I cut out the side of a gallon jug, laid on it's side it holds 1 gallon of the pink stuff). Hook the hose to the flush port on your jetpump, start the engine then turn on the bilge pump (I lengthened it's power leads to 6 feet so they can reach the battery in my RXT). Let it pump the anti-freeze in while the engine is idling. I used 2 gallons of the pink stuff in mine, it had pink water coming out the jet pump the overflow and out the exhaust. When you run out of anti-freeze kill the engine and then turn off the bilge pump and that's that.
    Also be sure to fog your engine, both while it's running with the antifreeze pumping and then again after you shut it off pull the plugs and spray storage/fogging oil in each cylinder for like 30 seconds then put the plugs back in and crank 20-30 seconds while holding WOT to keep it from starting... this coats the pistons, rings and cylinders with the storage/fogging oil fluid.
    The entire process takes a little less than 30 minutes start to finish. Do remember to charge your battery every month it's in storage or plug in a Battery Tender charger full time otherwise your battery will suffer and may even die a horrible low-voltage frozen death.
    Regards!
    - Michael
    0 Not allowed!
  6. #5
    Senior Member Mirage's Avatar
    Join Date
    Feb 2008
    Location
    Home of Wild Turkey 101 & Lake Cumberland Ky.
    Posts
    168
    Watercrafts
    04 Sharpe Houseboat 03 GTX 4tec 03 GTI LE RFI 93 Mirage River Racer 111mph 86 Laser LTV 90mph
    Thumbs Up
    Received: 1 Given: 0
    Default
    Quote Originally Posted by Michael211_2000 View Post
    Regards!
    - Michael
    Well said, but I would kill the pump before ahutting off the engine.
    My baby is BOTTLE fed, is yours???
    OUTBOARDS!!!
    CLICK HERE FOR THE VIDEO
    CLICK HERE FOR 2007 Poker Run pictures
    0 Not allowed!
  7. #6
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    FLorida, Southern Area
    Posts
    13,831
    Watercrafts
    2009 RTX X (255 hp supercharged / inter-cooled). 2010 GTX 155
    Thumbs Up
    Received: 642 Given: 5
    Default
    Good post,,
    Mine are still so new I am doing the dealer thing. I have under 15 hrs on them thus far..
    0 Not allowed!
  8. #7
    Join Date
    Sep 2010
    Location
    Splendora, Texas
    Posts
    1,312
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Mirage View Post
    It doesn't matter if you've pumped all the antifreeze in already. Bilge pumps (like I use for this process) can run dry without harm. But whatever floats your boat, either way it doesn't matter in this case.
    Regards!
    - Michael
    0 Not allowed!
  9. #8
    Join Date
    Apr 2009
    Location
    St. Marys, Ohio
    Posts
    1,909
    Watercrafts
    Thumbs Up
    Default
    He said kill the pump before shutting off the engine so you don't fill your engine with antifreeze. The antifreeze will backflow into the motor through the exhaust if it isn't running, just like a 2 stroke.
    0 Not allowed!
  10. #9
    Join Date
    Sep 2010
    Location
    Splendora, Texas
    Posts
    1,312
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by ski-d00 View Post
    Not if you've already pumped your antifreeze pan dry.... ya'll not reading what I typed there! :-(
    - Michael
    0 Not allowed!
  11. #10
    Junior Member
    Join Date
    Jun 2012
    Location
    MICHIGAN
    Posts
    3
    Thumbs Up
    Default
    I supposed this is obvious to most of you but I just want to make sure I'm adding antifreeze to the right parts. Which hoses do I add antifreeze to?
    0 Not allowed!
  12. #11
    Senior Member
    Join Date
    Aug 2011
    Location
    NY
    Posts
    141
    Watercrafts
    '08 C180SE
    Thumbs Up
    Received: 7 Given: 0
    Default
    Hopefully you mean....
    Quote Originally Posted by andrew224 View Post
    helped a friend winterize his 05 rxt, pulled hoses off intercooler in the front of the engine , and no water came out , drained exhaust manifold a few drops came out, pour about 10 oz of af into manifold which is pretty straight forward. as the manual states install bottom hose on intercooler and pour about 8 oz of af , we did exactly that took fill hose off and af ran out of fitting, so we put the top hose back on intercooler and pour some more af into bottom fitting of ic, took fill hose off and not much came out. the bottom fitting of the ic says in and the top ic fitting says out . did we do this correctly?
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. intercooler help
    By mike79 in forum 4-Tec Sea-Doo Boats
    Last Post: 05-10-11, 09:21 AM
  2. Special precedures For Winterizing 08 255 Supercharged
    By Sticks-RXPX-255 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 09-30-09, 02:23 PM
  3. Pictures: 2009 Long Beach to Catalina & Back Race Pictures
    By Socaloffshore in forum West Coast
    Last Post: 08-22-09, 02:17 AM
  4. rxp intercooler winterizing
    By sprkplug65 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 11-28-08, 07:11 PM
  5. RXP 215 Intercooler
    By HOT-RED in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 03-29-08, 01:07 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
