Oil in the Crankcase - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 10 of 10
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Jul 2010
    Location
    Central IL
    Posts
    63
    Watercrafts
    94 Seadoo SPX
    Thumbs Up
    Received: 1 Given: 0
    Default Oil in the Crankcase
    Hey guys:
    94 SXP with a 657. Putting her back together after some engine work. I hooked up the oil connections, then without thinking, I took the pinchers off the oil lines. With the trailer pitched up, it filled the block with oil and oil was running out the exhaust port of the MAG cylinder.
    I tipped it a little and drained a fair bit out, but how much is too much? Do I need to tip the whole thing over and let it all drain?
    Thanks!
    0 Not allowed!
  2. # ADS
  3. #2
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,117
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    Default
    It's not suppose to fill the crankcase full of oil.
    You have a leak somewhere around the seals.
    0 Not allowed!
  4. #3
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    SeaDoo's: 96 GTI 720, 95 XP 800 Limited, 96 GSX 787. 2000, 18' Bayliner 3.0L.
    Thumbs Up
    Received: 342 Given: 40
    Default
    You have a two stroke engine, it doesn't get crankcase oil, you need to get as much out as you can. You've probably got bad crank seals.
    Lou
    "I would rather be lost at the lake than found at home."
    My reading of history convinces me that most bad government results from too much government.
    -Thomas Jefferson-
    I believe the best SOCIAL PROGRAM is a JOB!
    -Ronald Reagan-
    If I had Canadian soldiers, American technology, and British officers I could rule the world.
    -Winston Churchill-
    0 Not allowed!
  5. #4
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Sea Doo 95, XP, SPX, GTX, SPI, XP, 97 Polaris Hurricane
    Thumbs Up
    Received: 36 Given: 3
    Default
    Maybe made a mistake of oil line where cooling line attaches? On the lower exhaust manifold is a cylinder drain line. Below that on the lower case is the oil cavity gear return line to the oil tank.
    http://partsfinder.onlinemicrofiche....&B=13&Action=O
    http://partsfinder.onlinemicrofiche....&B=14&Action=O
    Here is a carb side pic for reference. Copper drains were added to this motor, and you can see the large cavity oil line nipple in the lower case.
    http://www.pwctoday.com/photopost521...4&ppuser=46023
    Hope this helps
    Bills86e
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Join Date
    Jul 2010
    Location
    Central IL
    Posts
    63
    Watercrafts
    94 Seadoo SPX
    Thumbs Up
    Default
    Thx Bill. In your second link, the line in the lower LH corner is what was running. It runs from the oil filter to the bottom of the injection pump. When I pulled the line off the filter, oil was running out pretty well. What's going on?
    Thx!
    Quote Originally Posted by Bills86e View Post
    Hope this helps
    Bills86e
    0 Not allowed!
  7. #6
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Thumbs Up
    Default
    Gravity! After you connect it and zip tie it securely on the injection pump nipple, loosen the bolt thats between that nipple and the lever arm to let any air bubble escape, then tighten. With motor at idle you can hand pull the lever counter-clockwise to prime the two injection lines to the RV spigot tubes in the RV cover.
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Jul 2010
    Location
    Central IL
    Posts
    63
    Watercrafts
    94 Seadoo SPX
    Thumbs Up
    Default
    Thanks Bill. I knew it was just gravity running from the reservoir, but I'm not sure I understand what stops this from happening any other time. I found the bleeding section in the manual, but what stops this from happening during normal use? Do I have bad seals somewhere (like was mentioned above)?
    Thanks again!
    0 Not allowed!
  9. #8
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Thumbs Up
    Default
    You are dealing with two gravity fed oil systems. The injection pump is rotary shaft spindle driven to pump oil to the carb flange RV cover spigots, where the oil gets squirted into the gas-air mixture and enters the two lower cases compartments where it lubs the crank journals,
    piston wrist pin bearings and cylinder walls. The other is a rotary gear circulation system that is fed by the large 12mm hose on oil tank bottom, and the helical action of the two rotary gears circulate the oil tru the gear cavity, out the exhaust side of the cases, and pushes it until it falls back into the top of the oil tank. There are seals in the cavity on each side of the gear, on the crankshaft. When they go bad they leak oil into the case compartment below the piston. When it becomes excessive like smoking out exhaust, its time to replace the crank as the fix for leaky seals. The two small 3/32"id oil lines need replaced every 2-3 years. They are Tygon weedeater fuel line. The other oil & fuel lines every 5 years. We recommend ethanol (alcohol) resistant fuel lines like Bingo or Gates or Goodyear.
    Bills86e
    0 Not allowed!
  10. ☑ ORIGINAL POSTER #9
    Join Date
    Jul 2010
    Location
    Central IL
    Posts
    63
    Watercrafts
    94 Seadoo SPX
    Thumbs Up
    Default
    So it would seem that my crank seals are not sealing then, correct? I put a rebuilt crankshaft into this engine this summer, so the crank seals are brand new. If this is case, I've got a MAJOR problem with my supplier.
    How could they be bad right off the bat?
    0 Not allowed!
  11. #10
    Minnetonka4me's Avatar
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,785
    Watercrafts
    3 Modded 96XPs -=- 93 GTX for the GF -=- and over 300 as parts for sale! -=-
    Thumbs Up
    Received: 174 Given: 275
    Default
    Its possible that they didnt find their groove as you put it together..? They need a little sealant around the outer lip too when you assemble.
    Nick @ www.westsidepowersports.com -your Seadoo specialists!!
    Current part out list; Click below to view pictures. PM for availability & pricing
    Ride it like you ain't got a dime in it!!!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 787 crankcase oil
    By fastscottie in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-06-11, 05:42 PM
  2. Oil in crankcase
    By Phildoo in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-28-11, 04:06 PM
  3. 96 xp crankcase
    By thejacksonkid910 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 03-29-10, 03:13 PM
  4. Crankcase oil ??
    By jsun3701 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-06-08, 01:16 PM
  5. Seadoo Gti crankcase??
    By seadoogti7 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 03-16-08, 11:04 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
