Bailer (jet-pump) - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 1 of 1
  1. ☑ ORIGINAL POSTER #1
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Sea Doo 95, XP, SPX, GTX, SPI, XP, 97 Polaris Hurricane
    Thumbs Up
    Received: 36 Given: 3
    Default Bailer (jet-pump)
    The bailer systems suction box's are held to the floor by two stainless spring holders. The two lines have a 90* fitting where they are zip-tied under rear seat compartment, then go back down to attach to the two smaller of three (3rd is water pressure inlet line) nipples from the jet-pump. The venturi houseing has veins that lead out of ventiri rear where two bailer tubes are inserted, and protrude into the outgoing jet wash, that provides a constant bilge suctioning thru this system of tubes and its bailer box. If the zip-tied lines fall or the tubes break or fall out the system fails and water can ENTER into the bilge, your ski could sink!
    Seadoo 140MM jet-pump venturi bailer tubes - dual taper
    Newer style tubes '96-up white/clear Pt #271000464 lenghth 3 1/8" 80MM
    Old School style tubes '88-'95 black Pt # 293700017 lenghth 1 7/8" 48MM
    Jet pump bailer screw-in fittings are Pt # 393700017
    I get these from RIVA. Briand@rivamotorsports.com
    Bills86e
    This is just information.............no Q ......please.
    0 Not allowed!
  2. # ADS
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. bailer pick ups filling my boat
    By dpvandy01 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 06-21-11, 10:55 PM
  2. replace mechanical fuel pump with electric pump on an 89 sp
    By hypersniper2010 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-06-10, 05:59 PM
  3. 95 GTX siphon bailer o-ring failures
    By gjkovach in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-08-10, 10:40 AM
  4. Bailer pickup tubes & Engine water inlet removal
    By mshelton911 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-30-09, 08:35 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
