Removing Battery - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 23 of 23
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jul 2011
    Location
    Annapolis, MD
    Posts
    10
    Watercrafts
    2001 GTX-DI 2011 GTI-SE 130 2009 Yamaha 212SS
    Thumbs Up
    Received: 0 Given: 0
    Default Removing Battery
    Does anyone know how to remove a battery for 2011 GTI-SE 130? I know this may sound stupid but it looks a little confusing then my 2001 Sea-Doo GTX-DI battery, where you just have the negative and positive wires. Also any pics would also help a lot too, thanks.
    0 Not allowed!
  2. # ADS
  3. #2
    SeadooForum Pro ski-d00's Avatar
    Join Date
    Apr 2009
    Location
    St. Marys, Ohio
    Posts
    1,929
    Watercrafts
    2012 RXPX 2012 GTR 215 2006 3D DI 2005 Speedster 200 SC 370HP
    Thumbs Up
    Received: 69 Given: 1
    Default
    remove the 2 screws on each side of the battery case at the bottom, then unclip the case halves at the top and the halves will separate, unbolt connections and remove battery. not hard but more complicated than it needs to be.
    seadoo has gotten carried away with their accessory parts, imo. part of the reason these things cost so much now. they don't seem to agree with simpler is better.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jul 2011
    Location
    Annapolis, MD
    Posts
    10
    Watercrafts
    Thumbs Up
    Default
    Thanks ski-d00 for your help
    0 Not allowed!
  5. #4
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    FLorida, Southern Area
    Posts
    13,880
    Watercrafts
    2009 RTX X (255 hp supercharged / inter-cooled). 2010 GTX 155
    Thumbs Up
    Received: 651 Given: 5
    Default
    I was not able to un-clip and halve the plastic case that is around the battery.
    I unplugged the wires from the various relays and removed it pretty much as a unit. Once i had it out, I was able to split the halves easily. I did so and put the halves back into the ski with all the wires plugged back in.
    0 Not allowed!
  6. #5
    Junior Member
    Join Date
    Nov 2012
    Location
    Michigan
    Posts
    3
    Watercrafts
    2012 RXT-260 2004 RXP-215
    Thumbs Up
    Default
    I removed the battery from my 2012 Sea-Doo RXT 260 for the first time today...
    - Disconnect terminal connections with Phillips head screwdriver
    - Remove the the two 1/2" bolts on each side of the battery case at the bottom with a socket wrench and a long extension. Be careful not to lose the flat washers when you remove the bolts.
    - Unclip battery case halves at the top (using your hands)
    - FULLY SEPARATE THE CASE HALVES BY ALSO SEPARATING THEM AT THE BOTTOM WHERE THEY ARE TABBED TOGETHER VERTICALLY IN THE LOCATION WHERE THE BOLTS WENT THROUGH. It won't come apart if you don't pull up on one half and down on the other to separate the halves. The tabbing direction is reversed on the left vs. right sides, so reverse your up/down force to separate the halves on the 2nd side you attack.
    As "ski-d00" mentions, this is not difficult but it's sure more complicated than it needs to be.
    Sea-Doo Battery Removal
    0 Not allowed!
  7. #6
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,118
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    Default
    Michiganski...
    Welcome to the forum.
    What city are you near.
    See my signature below for a group in SDF (SeaDooForum.com)
    For members in Michigan, please read the following thread & post your info.
    http://www.seadooforum.com/showthrea...-Michigan-Here
    If you wish to have your first name known to other members please sign up in this thread. http://www.seadooforum.com/showthrea...ht=#post313624
    To all Michigan boat owners, there is a new group in SDF called MICHIGAN WATERRIDERS. Click on Community at top of pg. & find Michigan Waterriders.
    "Beware of little expenses; a small leak will sink a great ship." ~ Benjamin Franklin
    0 Not allowed!
  8. #7
    Junior Member Joby's Avatar
    Join Date
    May 2008
    Location
    Irvine, CA
    Posts
    14
    Watercrafts
    Current 2012 Sea-Doo Wake 155 Retired 96 Sea-Doo GTX 97 Sea-Doo GTX
    Thumbs Up
    Default
    Hi,
    So I got the battery case out after prying off the accessory bracket, now I need to get it back together, how the **** do you clip the accessory (fuse) bracket back onto the battery case? I just can't see how to do it...
    2012 155 Wake
    Thanks
    0 Not allowed!
  9. #8
    Junior Member
    Join Date
    Nov 2012
    Location
    Michigan
    Posts
    3
    Watercrafts
    Thumbs Up
    Default
    Joby,
    As I was trying to remove my battery yesterday, my first inclination was also to pry at that fuse bracket to see if it would come off (it almost beggs to be pried at). It felt like it might break if I applied too much force, so I went online and found this thread. From reading Ski-Doo's post I decided I must have missed something because he didn't mention having to pry at anything. When I went back to it, I found that the separation of the halves was possible with your hands alone and didn't require the fuse bracket to be removed at all.
    Do you think you could have broken it? Maybe we could help if you sent photos.
    Good luck! Let us know if you figure it out. I'm guessing you're not the first one to pry the fuse bracket off.
    For others - please note that the fuse bracket doesn't require removal to get the battery out; it can stay connected to its half of the battery case and the battery will still come out.
    0 Not allowed!
  10. #9
    Join Date
    May 2008
    Location
    Irvine, CA
    Posts
    14
    Watercrafts
    Thumbs Up
    Default
    Thanks for the reply, I fixed it in the end, it was not splitting the case I had a problem with, it was getting the bracket back on the side of the case. I had already taken the bracket off and replaced the batt, of course now I know how it goes I know I did not need to take the bracket off the side.
    I took the batt and case out again and then disconnected all the wires from the bracket. Once I had the batt case and the bracket out of the dark hole it was easy to see how to clip it back on.
    There are two tabs at the bottom of the bracket, they slide behind the bottom bar of the batt case, then you have to pull (hard) the top of the bracket (where the white module connector fits) up and over the top of the case, so that the clip locks into the batt case.
    I would have taken pics if I had thought of it at the time sorry, if I every have to do it again I'll take pics...
    thanks!
    0 Not allowed!
  11. #10
    Senior Member Piper Mike's Avatar
    Join Date
    Aug 2012
    Location
    MISSISSAUGA
    Posts
    107
    Thumbs Up
    Received: 3 Given: 0
    Default
    Just noticed this contraption on my 2013. Already snapped one of the top tabs trying to separate the case before I found this thread.....Almost better off to just take the wires off the battery and charge it in it's fancy holder. Guess we shouldn't take the battery out unless it's in need of replacement ?
    0 Not allowed!
  12. #11
    Junior Member
    Join Date
    Aug 2013
    Location
    Eastern Shore Maryland
    Posts
    9
    Watercrafts
    sea doo 2004 2011 gti se
    Thumbs Up
    Default
    there is a plastic panel? that i cant take out of jet ski to get to battery arms black n blue from this darn plastic panel whats the trick to moving this panel thankyou
    0 Not allowed!
  13. #12
    Join Date
    Apr 2009
    Location
    St. Marys, Ohio
    Posts
    1,929
    Watercrafts
    Thumbs Up
    Default
    the plastic panel has two black plastic push pins at the bottom. with a small screw driver, gently pry the pin about a 1/4" out but the pin doesn't have to be completely removed, just out some, then the entire pin will come right out. once both pins are out, slide the panel UP FIRST, don't just pry it out, it has hook tabs on each side, then it comes right out and you'll all the access you need to the battery.
    0 Not allowed!
  14. #13
    Join Date
    Sep 2013
    Location
    menomonee falls, wi
    Posts
    40
    Watercrafts
    2013 Seadoo GTI 130 SE - Lucky Green
    Thumbs Up
    Received: 3 Given: 6
    Default
    I was able to remove the battery inside of its fancy holder after un-bolting the pos+neg cable along with the 2 bolts on the bottom. once i got the whole assembly loose i lifted it up a bit and was able to pop the fuse assembly off by hand from the bottom side first.
    Be carful not to loose those lil square nuts inside the battery terimals! i lost one by tilting the battery a smidge and under the fuel tank it fell.
    i def agree on how crazy complicated it is to get that battery out. way to much.
    0 Not allowed!
  15. #14
    SeadooForum Hall of fame Sportster-2001-951C-Stock's Avatar
    Join Date
    Jun 2013
    Location
    Virginia Sea Level
    Posts
    6,904
    Watercrafts
    2001 Sportster LE 951 Carbed
    Thumbs Up
    Received: 284 Given: 47
    Default
    Try a sawzzall?
    0 Not allowed!
  16. #15
    Member kunzman's Avatar
    Join Date
    Oct 2012
    Location
    Cleveland, OH
    Posts
    49
    Watercrafts
    2012 GTI 130
    Thumbs Up
    Received: 1 Given: 0
    Default
    Quote Originally Posted by Freddyk79 View Post
    It will eventually make its way to the back of the ski. Check back near the rear of the ski after a few runs.
    Todd
    2012 Sea Doo GTI 130
    0 Not allowed!
  17. #16
    Coastiejoe's Avatar
    Join Date
    Apr 2011
    Location
    Posts
    13,880
    Watercrafts
    Thumbs Up
    Default
    Take a wire tie and wrap it around the terminal. The square metal nut can't fall out...
    0 Not allowed!
  18. #17
    SeadooForum Pro lamajama's Avatar
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,059
    Watercrafts
    04 GTX SC, 02 GTX 4 tec
    Thumbs Up
    Received: 23 Given: 18
    Default
    I used a short piece of the clear hose that comes with a vented battery and squeezed it between the battery terminal and the nut...I
    also went to the $1 store and bought a fabric dog collar and clipped it around the battery. Now I can lift the battery up without
    having it slip from my fingers....dumb idea but it works for me anyway....
    0 Not allowed!
  19. #18
    Junior Member
    Join Date
    Oct 2013
    Location
    United States
    Posts
    9
    Watercrafts
    2013 SeaDoo GTI SE 155
    Thumbs Up
    Default
    Removal was relatively straightforward thanks to this thread (though on mine there was no square nut... either that or I've lost them without knowing.) One clarification: the bolts at the bottom of the bracket for me were 13mm, not 1/2 inch. And getting your hand down in the tight space to get them out without losing the washers was dicey.
    I'm also not looking forward to putting that sucker back in...
    0 Not allowed!
  20. #19
    Junior Member strake's Avatar
    Join Date
    Sep 2010
    Location
    Moneta, VA
    Posts
    23
    Thumbs Up
    Default
    Great read, as I'm about to replace our GTXiS 2010 battery. I started looking in the dark hole, and can see the two 13mm bolts at the bottom that hold the battery assembly in place.
    Does anyone know what the battery dimensions are, as I haven't taken it apart yet. I would prefer to buy an AMG battery rather than the one that came with it (acid screw fills). The local Sea Doo dealer only sells the stock, acid style battery. since this sits in the fancy battery holder, I need to get one basically identical in outside dimensions. I just don't know what those measurements are.
    thanks
    Richard
    Strake
    Gettysburg Pa / Smith Mountain Lake VA
    2010 GTXis 215
    0 Not allowed!
  21. #20
    Junior Member
    Join Date
    Oct 2013
    Location
    United States
    Posts
    9
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by strake View Post
    thanks
    Richard
    Mine is 6 3/8" x 5" and 7 1/2" high.
    0 Not allowed!
  22. #21
    Join Date
    Jan 2010
    Location
    Vancouver BC
    Posts
    1,059
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by BMoreE View Post
    Mine is shown as a CTX30L and is 6 1/2" wide by 5" deep and 7" tall. 2004 GTX
    0 Not allowed!
  23. #22
    Join Date
    Sep 2013
    Location
    Ontario
    Posts
    68
    Watercrafts
    2010 Yamaha VX Deluxe 2012 Sea-Doo GTI SE 155
    Thumbs Up
    Received: 4 Given: 0
    Default
    Most complicated ridiculous setup I have ever seen. Obviously Seadoo has too many engineers with nothing better to do.
    0 Not allowed!
  24. #23
    Join Date
    Sep 2010
    Location
    Moneta, VA
    Posts
    23
    Thumbs Up
    Default
    Quote Originally Posted by Grapeescape View Post
    I agree......... that's why I was asking for specifics........ fancy, over engineered plastic housing to hold the battery makes for less choices on getting a battery replaced. Let alone the task of doing so....
    thanks folks for the replies.
    Richard
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 4
    Last Post: 08-08-11, 05:49 AM
  2. Removing Engine
    By BMX2FOUR7 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-25-10, 03:23 PM
  3. Removing bad gas 93 xp
    By JetSkiSeeker in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-22-10, 01:33 PM
  4. removing pto
    By mike martinez in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-10-08, 05:14 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
