what can you tell about this spark plug? - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 17 of 17
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Aug 2009
    Location
    usa
    Posts
    53
    Watercrafts
    1999 seadoo xp ltd. stock
    Thumbs Up
    Received: 0 Given: 0
    Default what can you tell about this spark plug?
    i know its not the gratest picture but what can you tell about this BR8ES with low hours.
    0 Not allowed!
  2. # ADS
  3. #2
    RFoster130's Avatar
    Join Date
    Mar 2009
    Location
    Northern KY
    Posts
    5,426
    Watercrafts
    2012 Challenger SE 230. 510HP Formerly 2004 Speedster 200 310HP 1998 Speedster 220HP
    Thumbs Up
    Received: 33 Given: 12
    Default
    From that angle it looks pretty normal to me. A better picture of the bottom would help. Here is a link to a great writeup snipe did. Scroll down the thread and look at the spark plug section.
    http://www.seadooforum.com/showthrea...-Snipes-Korner...
    0 Not allowed!
  4. #3
    SeadooForum Hall of fame SabrToothSqrl's Avatar
    Join Date
    May 2009
    Location
    PA
    Posts
    5,424
    Watercrafts
    2002 GTX & XP
    Thumbs Up
    Received: 163 Given: 2
    Default
    I can tell your right handed. that it's most likely a 951 engine, and that you took the photo above a piece of paper in your parent's basement.
    and it almost looks like the piston hit it.
    we need to see the ceramic
    0 Not allowed!
  5. #4
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    I can't tell a dam thing.
    Bad angle, and blurry. BUT... as above... it looks crushed... but it could be the angle.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  6. #5
    SeadooForum Pro crisso's Avatar
    Join Date
    Jan 2010
    Location
    Gold Coast Australia
    Posts
    1,543
    Watercrafts
    Dec.1998 GTX Limited 1750 Bullet200 merc 32 carvel hull trawler.Spotted gum.11.1 ton 2012 GTI 130
    Thumbs Up
    Received: 6 Given: 0
    Default
    That plug looks hit!.Wrong plug.Engine heads shaved,Crank stroked.Rave valves gone loose.Broken ring piece.Some thing loose has hit it and maybe shot out the exhaust port
    0 Not allowed!
  7. #6
    LouDoo's Avatar
    Join Date
    May 2010
    Location
    Lexington, KY
    Posts
    12,674
    Watercrafts
    SeaDoo's: 96 GTI 720, 95 XP 800 Limited, 96 GSX 787. 2000, 18' Bayliner 3.0L.
    Thumbs Up
    Received: 342 Given: 40
    Default
    Quote Originally Posted by SabrToothSqrl View Post
    Congratulations, this is one of the best answers I've seen on this forum. I'm happy to see people with a sense of humor.
    Lou
    "I would rather be lost at the lake than found at home."
    My reading of history convinces me that most bad government results from too much government.
    -Thomas Jefferson-
    I believe the best SOCIAL PROGRAM is a JOB!
    -Ronald Reagan-
    If I had Canadian soldiers, American technology, and British officers I could rule the world.
    -Winston Churchill-
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Aug 2009
    Location
    usa
    Posts
    53
    Watercrafts
    Thumbs Up
    Default yheap its hit
    so yea something did hit it but WHAT and WHY?? i saw 2 small marks on the arm there thats also making contact with the "electrode"? when i took the plug out.
    so far this is what i have done (in that order)...
    cranked the engine trying to expell foreing object in cyl. and listened for wierd noises.
    put diferent plugs and ran fine afterwards (20-30min run)
    compresion on both cyl was fine (150psi each)
    took the RAVE valve for that cyl out and didnt see any missing pisses or anything loose.
    "crisso
    That plug looks hit!.Wrong plug.Engine heads shaved,Crank stroked.Rave valves gone loose.Broken ring piece.Some thing loose has hit it and maybe shot out the exhaust port"
    as far as i know its a stock engine from SBT that was running fine.
    one thing i did notice was that the small hose on the exhaust, the 1 that vents to the ouside on the hull, right after the cylinders by the choke cable was pinched for that run.
    man this worries me a lot and i'm going nuts trying to figure this out. thank you all!
    edit---> also could the piston travel that far up to meet the plug like that? if it wasnt the piston then it was a pretty random hit by another object. weird thing is no rattles, vibrations or noises out of ordinary.
    0 Not allowed!
  9. #8
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,299
    Watercrafts
    Sea Doo 95, XP, SPX, GTX, SPI, XP, 97 Polaris Hurricane
    Thumbs Up
    Received: 36 Given: 3
    Default
    Just judgeing the wash is somewhat white, indicating a rich mixture. IMO Threads/seal ring indicate it was not in torque spec.
    0 Not allowed!
  10. #9
    Experienced Rider Sink's Avatar
    Join Date
    Jul 2011
    Location
    Denton, NE
    Posts
    543
    Watercrafts
    1995 Seadoo Speedster
    Thumbs Up
    Default
    You guys missed that there had been a staple in the paper, it had been folded and a fly had landed on that paper within the last 7.35 seconds.... give or take a few seconds.
    Why did you pull the plug? Was the engine running fine? Was there a noise? How long have you had this engine? (how many hours?) How long had it been since you pulled the plug before and was there an event that made you remove it and look at it?
    0 Not allowed!
  11. #10
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    If it was hit while in the engine... it was a foreign part. The piston can't get that high. Even is you shaved the head... the piston would hit the squash band section of the head first.
    If that came out of one of my engines... I would pull the head off, and check for other damage. If you cracked the piston crown at the rings.... you may have a ticking time bomb. Opening it up may save you a melt-down.
    0 Not allowed!
  12. ☑ ORIGINAL POSTER #11
    Join Date
    Aug 2009
    Location
    usa
    Posts
    53
    Watercrafts
    Thumbs Up
    Default wtf man
    why is the damage so consentrated to that small area on the left side on both piston and head?? i got no idea what happened. something must have come loose from within the engine/exhaust/ intake at the end scince i had about 4 short runs before it stop firing in that cyl.
    there seemed to be a little water on both cyl i dont understand why. and what about those irregular burn marks on top, is that normal?
    would the dings and dents cause preignition and detonation so bad that it could self destruct if i ride like that?
    this is messed up i feel ill. oh well at least i got to jump some waves this summer.
    0 Not allowed!
  13. #12
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    Thumbs Up
    Default
    The water probably came from a leaky head gasket.
    I would pull the jugs and replace that piston. It could crack. The head is OK, unless it twisted.
    0 Not allowed!
  14. ☑ ORIGINAL POSTER #13
    Join Date
    Aug 2009
    Location
    usa
    Posts
    53
    Watercrafts
    Thumbs Up
    Default
    ok so the update is as fallows... engine is out of the xp to be rebuilt early next year. cleaned the fuel selector valve and replaced the tempo fuel lines with gates barricade hoses from napa. i was looking for goodyear hoses but its a pita trying to locate by the ft. and the gates ones look pretty high quality + the tech at napa wave me a lifetime warranty printout from gates. anyone with a '99 xpl you only need 7ft 5/16 and about 10ft 1/4 hose. no green stuff in lines but the reserve on the selector valve had a dried up plug so i cleaned that and made sure its flowing nice now.
    also took the foot mats out...to be replaced with hydro-turf mats...
    0 Not allowed!
  15. #14
    Join Date
    Jan 2010
    Location
    Posts
    1,543
    Watercrafts
    Thumbs Up
    Default
    Why did this happen.Did it nip a ring?
    Why is it,that when you are driving and looking for an address,You turn down the volume on the radio?
    0 Not allowed!
  16. #15
    Join Date
    Jan 2010
    Location
    Posts
    1,543
    Watercrafts
    Thumbs Up
    Default
    has this motor got reed valves?
    0 Not allowed!
  17. ☑ ORIGINAL POSTER #16
    Join Date
    Aug 2009
    Location
    usa
    Posts
    53
    Watercrafts
    Thumbs Up
    Default yhes and yhes its got reeds and raves valves...
    ... but when dealing with this kinds of problems its best to ask "why" at least 5 times to get to the root. so lets see, why was the piston and plug hit?
    -because the wrist pins broke loose. why did the wrist pins came loose?
    -because the wrist pin cage broke? why did the cage brake?
    -my guess would be because lack of proper lubrication (lean condition). why was there a lack of proper lubrication?
    -because the carburetor gasket was reused several times developing a faulty seal. and why was the carburetor gasket reused several times....welll u know the rest duhh!
    0 Not allowed!
  18. #17
    Seadoobuddy's Avatar
    Join Date
    Jul 2011
    Location
    White Lake Township, Michigan, also some in Bradenton, Florida
    Posts
    7,118
    Watercrafts
    96 GTX , 99 GSX Limited, 19 ft. Glastron I/O boat.
    Thumbs Up
    Received: 108 Given: 36
    Default
    Well, at least you know whom to blame.
    sorry for your loss. But now you know what to do to repair it.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Spark plug gap
    By dml2010 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-10-11, 10:24 PM
  2. Spark Plug Gap - .020 - .024???
    By sc419795 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-06-11, 06:56 PM
  3. spark plug gap
    By verk182 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 06-08-10, 06:34 PM
  4. Spark Plug help
    By SIDEWINDER in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 06-03-10, 07:34 PM
  5. Spark Plug Gap
    By bbs15 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-01-09, 09:36 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
