'10 Challenger 210 SE - Water inside Hull storage compartment - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 5 of 5
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    May 2011
    Location
    TX
    Posts
    6
    Watercrafts
    2010 Challenger 210 SE
    Thumbs Up
    Received: 0 Given: 0
    Default '10 Challenger 210 SE - Water inside Hull storage compartment
    Hello Guys,
    I bought this boat last week.
    There is water inside of the hull storage compartment ( ski storage ) and I do not know how to get it out. I turned on the pump and opened the drain plug (on the lift) and nothing comes out. Water is just in there.
    Please advise
    0 Not allowed!
  2. # ADS
  3. #2
    Junior Member
    Join Date
    Dec 2010
    Location
    MARSEILLES,ILLINOIS
    Posts
    5
    Watercrafts
    40 FT HARBORMASTER 2009 SPEEDSTER 200 43OHP
    Thumbs Up
    Default water in ski locker
    My 09 speedster 200 does the same thing,raise the front of the boat higher than normal and it will run out to the bilge and out the drain plug.
    0 Not allowed!
  4. #3
    Junior Member
    Join Date
    Jun 2010
    Location
    TN
    Posts
    4
    Watercrafts
    Sea Doo Challenger 180
    Thumbs Up
    Default
    I had the same issue with my 2008 Challenger 180 SE. I eventually took it in to my local dealer for troubleshooting and they found that the fiberglass around the driveshaft was defective. It had air bubbles in the fiberglass and allowed water to constantly (all though very slowly) leak in which always kept the storage locker full of water. Since the bilge pump sits back by the motor and slightly higher than the water in the storage locker, the water was never pumped out. The good news is that Sea Doo did agree to repair the fiberglass issue. The bad news: They took 4 months to approve the warranty work and my boat sat in the shop the entire time. Since I got my boat back the water issue in the storage locker was much better but then the super charger failed (another week in the shop and a few hundred $$$). A couple weeks after that the cam chain failed which destroyed the engine. The engine had 74 hours on it! Even though it was out of warranty by then, they agreed to replace it with a remanufactured engine. I haven't gotten it back yet but when I do I'll probably use it for the rest of this season and then sell it and move on to something more reliable. The only conclusion I can make is that Sea Doo builds some very low quality products. I would give them high marks for "fun factor" and I think their boats are definitely designed with the true boater enthusiast in mind. But that is where I believe the positives end. Good luck with your water leak issue. Hopefully yours will be an easier fix than mine. Make sure you check all your fuses. There is also usually an inline fuse for the bilge pump which can be hard to find. Most of all...Happy boating!!!
    0 Not allowed!
  5. #4
    Member seadoomichael's Avatar
    Join Date
    Apr 2009
    Location
    Burlington, Wa
    Posts
    62
    Watercrafts
    2008 Seadoo Challenger 180 SE
    Thumbs Up
    Default
    Have you guys seen this thread/poll here?
    http://www.seadooforum.com/showthrea...t=water+locker
    20 out of 22 who responded says this is a normal condition with these/their boats. The mechanics on the board claim that the "carbon seals" are designed to leak for cooling purposes. I've come to accept it but rgrinch's experience is interesting...
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Junior Member
    Join Date
    May 2011
    Location
    TX
    Posts
    6
    Watercrafts
    Thumbs Up
    Default
    LIfted the front end and all of the water came out after opening the drain plug.
    Thanks for the help.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Water inside engine compartment
    By licketysplit in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-26-10, 03:44 PM
  2. water in storage compartment
    By earOhio in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-18-10, 12:12 PM
  3. Water inside 1991 hull
    By AmnonMikeCohen in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 06-12-10, 04:32 PM
  4. Storage compartment water issue
    By Lac Doré in forum Non-Seadoo PWC Talk
    Last Post: 04-27-09, 01:03 AM
  5. GTI LE RFI oil and water inside hull
    By will shook in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-04-08, 04:47 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
