Gray gooey substance coming from exhaust..... - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 8 of 8
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Mar 2011
    Location
    Puerto Rico
    Posts
    1
    Watercrafts
    94 Sea Doo Bombardier Jetski
    Thumbs Up
    Received: 0 Given: 0
    Default Gray gooey substance coming from exhaust.....
    My wife and I just bought a used 1994 Sea Doo Bombardier Jetski with a rebuilt engine. The guy we bought it from said it was a fresh rebuilt engine. When we got home and started it with a water hose we noticed a grayish gooey substance dripping from the exhaust. Any idea on what is causing this and/or what the problem might be? Your help is much appreciated - we've had it for over a month now and are anxiously waiting to take it out into the ocean, but not before we fix the problem!
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    It's just oil mixing with water. If it's been sitting... that's kind of normal.
    If it seems like it is running right... take it to the lake, and give it a ride. It will clear out.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. #3
    Minnetonka4me's Avatar
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,784
    Watercrafts
    3 Modded 96XPs -=- 93 GTX for the GF -=- and over 300 as parts for sale! -=-
    Thumbs Up
    Received: 174 Given: 275
    Default
    Its prob one of the reasons it was rebuilt...it prob hardly got run and their is still oil in the exhaust.
    Nick @ www.westsidepowersports.com -your Seadoo specialists!!
    Current part out list; Click below to view pictures. PM for availability & pricing
    Ride it like you ain't got a dime in it!!!
    0 Not allowed!
  5. #4
    Junior Member MIGUEL CARBAJAL's Avatar
    Join Date
    Jun 2009
    Location
    EL CENTRO, CA.
    Posts
    27
    Watercrafts
    1996 SEADOO GTX 2001 SEADOO GS
    Thumbs Up
    Default
    hey guys, sorry to butt in on your thread pramour787 but for some reason i cant make a new thread...I got a similar problem, maybe you guys can help me. I got a 96 GTX 787, i cleaned the carbs myself (my first time doing it). I put everything back together and started the ski with just the carbs/air filter on (but without the entire air box housing). ski started but gave me a scare cuz it rev'd really high. I assumed it was just sucking in to much air so I put a shop cloth over the air filter and the rev's came down. first question: (can u guys give me any advise on this I think i out everything back together correctly including the setting the high and low fuel adjments. can i adjust the high and low fuel needles while its running or is it just rev'ing really high cuz the air box housng isnt on?) ok, i also noticed a lot of white smoke. which is a new thing cuz it use to not smoke that much and the water coming out if the exhaust was really dark. I checked it and noticed oil in the water exiting out of the exhaust (seemed like a lot of oil to me) I ran it for 10 mintues with ahose and didnt get better or burn off...
    0 Not allowed!
  6. #5
    Join Date
    Jun 2009
    Location
    EL CENTRO, CA.
    Posts
    27
    Watercrafts
    Thumbs Up
    Default
    so i got white smoke and oil comming out of my exhaust (color varies a bit from greyish to dark)...any ideas?...the ski had been sitting all winter but i would think the oil would of burn off after 10 mintues of running with hose and ive never had oil come out hte exhaust before that i can remember
    0 Not allowed!
  7. #6
    Join Date
    Feb 2011
    Location
    Minnetonka, MN
    Posts
    6,784
    Watercrafts
    Thumbs Up
    Default
    again when they sit in storage oil seeps past the oil bath seals and into the crankcase. If its not too much you will get it to start, then it will smoke like crazy and maybe drip out the exhaust.
    Also note unless you are running it like you do on the lake, it will not suck all oil up and out until is run wide open and continue to smoke.
    10mins on the hose is NOT good. the thru hull seal needs water on it. You should not run a ski with a carbone ring hull seal more than a min or two.
    0 Not allowed!
  8. #7
    Join Date
    Jun 2009
    Location
    EL CENTRO, CA.
    Posts
    27
    Watercrafts
    Thumbs Up
    Default
    I ran it on the hose but 5min at a time, I was told that was ok but your right i need to take it to the lake, im going try to go today just to get the oil out...what if it doesnt stop leakn oil?.... bad gasket/seal somwhere?
    0 Not allowed!
  9. #8
    Join Date
    Jun 2009
    Location
    EL CENTRO, CA.
    Posts
    27
    Watercrafts
    Thumbs Up
    Default
    anything i should do before i take it to the lake?....im going to check the compression on the cylinders first...anything else?
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Grey Sludge coming from exhaust
    By gsxgtxman in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-18-10, 01:18 AM
  2. Oil coming out of exhaust
    By wizard213 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 06-17-10, 11:00 AM
  3. 1996 xp 800 oil coming out exhaust
    By frostblazer in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-18-10, 10:55 AM
  4. Gray Crap Comming out of exhaust.
    By sea_doo_man in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 04-21-09, 08:23 AM
  5. Oil coming out of exhaust
    By ILuvNkdChx in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 03-17-09, 11:43 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
