how to change your wear ring without removing your impellar!! - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 11 of 11
  1. ☑ ORIGINAL POSTER #1
    Rampage's Avatar
    Join Date
    Jul 2010
    Location
    Bradenton FL
    Posts
    1,107
    Watercrafts
    2004 RXP 245 racer 2002 GR800R 1996 XP 2004 RXP ramp ski
    Thumbs Up
    Received: 26 Given: 5
    Default how to change your wear ring without removing your impellar!!
    Read this on another site, and thought this is great.
    I just copied and pasted...but from reading all the replies, after you put your pump in the freezer you can pretty much tap the ring right out. Also they talk about flipping it around and using it twice.
    "it's the Freezer Method! I've used it several times now... it works great. Tip also that i learned from someone on the boards... you can use your wear ring twice.... just flip it over! yes it works... you can have your doubts, but please trust me.
    Nothing like having pictures do all the explaining
    in most normal wear circumstances this will work no problem. However if damage has been done to the wear ring excessively, you will still have a disruption in water flow and may experience SOME symtoms, but definitely improved over what it previously was."
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    I have been doing this method for years...I have posted it on out forum too lots of time. I never pull the impeller unless I have to.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Rampage's Avatar
    Join Date
    Jul 2010
    Location
    Bradenton FL
    Posts
    1,107
    Watercrafts
    Thumbs Up
    Default
    I had no idea it could be done this way. Have you ever flipped your wear ring around the other way to get more use from it
    0 Not allowed!
  5. #4
    Experienced Rider djredman99's Avatar
    Join Date
    Sep 2010
    Location
    Pittsburgh, Pa
    Posts
    908
    Watercrafts
    2015 Spark HO 2up, 2011 RXT-X 260, 1998 GSX Limited
    Thumbs Up
    Received: 7 Given: 1
    Default
    I like this. Will be warm enough to start working in my garage again soon. Definitely will try this approach.
    0 Not allowed!
  6. #5
    Senior Member Kozerxp's Avatar
    Join Date
    Jan 2010
    Location
    Ny
    Posts
    232
    Watercrafts
    2000 seadoo xp (sold) 2011 rxpx
    Thumbs Up
    Received: 0 Given: 0
    Default
    Worked great just about a hour in the freezer and knocked right out!!!!
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Rampage's Avatar
    Join Date
    Jul 2010
    Location
    Bradenton FL
    Posts
    1,107
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Kozerxp View Post
    Glad to hear it worked!!!
    0 Not allowed!
  8. #7
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,852
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default
    I have not done this and in my opinion, it avoids one of the biggest reasons to pull the pump; bearing inspection. If you've take the time to pull the pump to do a wearing ring, don't you think it's wise to check them? On occasion, the wearing ring could have worn to the degree, that the shaft developed a wobble. If this has happened, then you may have lost the clearnance on the shaft. Putting a new ring in with a bad set of bearings, will only cause gouging in the new ring, causing you to buy a new ring and replace the bearings anyway.
    My idea is, if you take something off to work, upgrade or replace, you should inspect every piece that is associated with what your repairing. It's kinda like the old saying, "do it once, do it right and you won't have to do it again"...
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  9. ☑ ORIGINAL POSTER #8
    Rampage's Avatar
    Join Date
    Jul 2010
    Location
    Bradenton FL
    Posts
    1,107
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by seadoosnipe View Post
    good point. Cant you feel if the bearings are worn? Wont there be some play or noise or anything?
    0 Not allowed!
  10. #9
    Join Date
    Apr 2011
    Location
    Summerville, SC
    Posts
    52
    Watercrafts
    1999 Sea Doo GSX 787 RFI 1999 Sea Doo GS 717 Carb'd
    Thumbs Up
    Default
    Quote Originally Posted by Rampage View Post
    Not always. I build transmissions, so I deal with torrinton and caged needle bearings everyday. You would be suprised, sometimes they feel good and sound good but when I get them apart they look like crap.
    1998 Sea Doo GSX Limited 951 TWINS
    0 Not allowed!
  11. #10
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,852
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by MonteC View Post
    Yes, your correct. The clearances are very small. The most important is the clearance at the seal. If the shaft is past the few thousandths thats allowed, you won't know that by just trying to move it by hand.
    BTW MoteC, I grew up in Goose Creek.......... It's a small world.
    0 Not allowed!
  12. #11
    Join Date
    Apr 2011
    Location
    Summerville, SC
    Posts
    52
    Watercrafts
    Thumbs Up
    Default
    Very small world.
    Ive been in Sville for the last 22 years.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Wear ring change
    By flip6 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-16-11, 07:31 PM
  2. Wear ring change
    By scottyp8 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-28-09, 12:32 PM
  3. Change wear ring without removing impeller?
    By swill777 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 11-03-08, 09:01 AM
  4. Replace wear ring w/o removing impeller, possible?
    By kmack in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-16-08, 12:34 AM
  5. How can I change the wear ring??? HELP
    By 96sportster in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-28-08, 11:36 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
