95 XP to 95 GTX carburetor swap - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 4 of 4
  1. ☑ ORIGINAL POSTER #1
    Senior Member Mgiffune's Avatar
    Join Date
    Jul 2010
    Location
    Atlanta
    Posts
    108
    Watercrafts
    1995 SeaDoo XP 1997 SeaDoo SPX
    Thumbs Up
    Received: 0 Given: 0
    Default 95 XP to 95 GTX carburetor swap
    I am a novice mechanic replacing the carburetor on my 95 XP 720 38mm carbs. The reason I am replacing - after replacing the gray fuel lines, wanted to rebuild the carb. One of the bolts is basically fused to the carburetor (PTO side) and will not come out. The top and bottom of the bolt have been sawed off (to remove it from the manifold).
    I've ordered a pair of carbs from ebay, however they are from a *1995 GTX (also a 720 / 38mm bore). The carburetor's are connected with a bracket (mine were separate) and seem to be 90 degrees out from the ones on my XP. Also, some of the fuel line ins are different. Will this setup work if I rebuild and simply attach? Or do I need to disassemble the pair, and install them configured the way my originals were? Looking for the easiest way with the best outcome. Thanks in advance!
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    The 95 GTX has a 657x engine... but you can make the carbs work. Are you getting the manifold too? If you are... use it, and you can make it a bolt on project. Otherwise, you will need to take all the hardware off your carbs, and rearrange them to work with your manifold.
    Also... the jetting is close, and the pop-off is low. So, I would rejet to the XP specs.
    Main 135
    Pilot 67.5
    Pop-off 40-56
    High 0
    low1-3/4
    Needle and seat 1.2
    Honestly... you should have looked for a set of 720 carbs int he same configuration. It would have been an easier project.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Jul 2010
    Location
    Atlanta
    Posts
    108
    Watercrafts
    Thumbs Up
    Default
    Dr Honda,
    Thank you for the reply. You've assisted me before and always been helpful. You may be right, I think the carbs were mis advertised. No, I do not have the manifold, just the carbs. I was planning on rebuilding anyway, so rejetting was planned.
    How much of a project am I in for making these work?
    0 Not allowed!
  5. #4
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    Thumbs Up
    Default
    It should be too hard. You will want to remove the throttle and choke shafts from your carbs, and put them in the new carbs. That will allow you to mount them properly. Other than that... you should be OK.
    If you can get your carbs apart... you can take the jet's out of them, and put them in the new carbs to save a few $$$.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. '96 SPI nut for carburetor
    By kimbrell224 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-18-10, 09:02 PM
  2. carburetor filters
    By acbprop in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-15-09, 03:22 PM
  3. 93 sp carburetor
    By mo11217 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-13-09, 12:03 AM
  4. Carburetor Question
    By SurfBeat in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-07-09, 03:47 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
