intake grate and impeller - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 10 of 10
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Received: 0 Given: 0
    Default intake grate and impeller 95 xp smashed lol
    So i hit a rock tonight and broke my intake grate and a piece got stuck in the jet pump. there doesnt seem to be a whole lot of damage but chances are its shot so i have a brand new rebuilt pump for my 95 spx sitting in a box and im wondering if it'll fit my 95 xp? (the one i hit the rock with) Also how important is an intake grate anyway because the one that was on my machine only had 2 bars across and i NEVER get sea weed stuck like everyone else i know, so can i run without it?? Thanks alot guys
    0 Not allowed!
  2. # ADS
  3. #2
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Yes... the pump will physically fit, but the impeller is probably the wrong pitch.
    The grate is really just protection for large objects. But, as you found out, large hard objects will break it.
    The grate on your ski helps significantly with how it handles. Those 2 bars act like fins, and give the ski "Traction" in the corners. (like tread on your car tires) Also, the part of the grate that bolts to the shoe (in the hull) it has a scoop on it. If you remove that scoop, you will find that you will have a problem with high speed cavitation.
    Back in the day... on our old stand up skis (kawi JS) we would cut way the intake grate, and weld the scoop into the pump shoe.
    I don't recommend doing that with your ski... but I have personally done it.
    If I was in your position... I would look for a used OE grate. They are cheap on eBay.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Default
    well i ordered a used one off ebay $15 so thats good....so if the impeller has a different pitch are you saying the machine will go slower? because my 95 SPX is almost as fast an my 95 XP so i could deal with it being the same speed as that machine.
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Default
    Anyone have anymore insight on the pitch of the impeller??
    0 Not allowed!
  6. #5
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,125
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by 2000mgt View Post
    GEEEZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
    You got to give it more than an hour or two.
    What ever the difference in pitch is, will be minimal because they are close to being the same machine. The pitch on the SPX will be a little lower, but the top speed of your XP shouldn't be drastically reduced. What you may find though, is the engine is able to reach the rev-limiter going flat out because of the slightly lower load on the engine.
    If putting you extra pump in the XP is so you can ride it this weekend... then go for it. If you are thinking it will be a perminate fix... just check the impeller before doing it.
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Default
    If it works it'll be a permanent fix, if it will go as fast as the spx then im happy with that! i really dont wanna spend more money on a new impeller if it wont make much difference
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Default
    so i have the pump all ripped apart anndd i have a bent drive shaft! sooo I seached ebay and cant fine on tried the parts tab at the top and its obsolite, so if anyone knows where to get a shaft for a 95 xp800 i need it! i dont know what can cross reverence with this machine but i dont find anything!
    0 Not allowed!
  9. #8
    Senior Member greyrider's Avatar
    Join Date
    Sep 2009
    Location
    hudson valley ny
    Posts
    180
    Watercrafts
    2000 LRV; 1993 XP; 1994 XP; 1994 SPX; 1993 Thompson Carrera 2000
    Thumbs Up
    Received: 1 Given: 0
    Default
    google part number 272-000-021 and you will see who has it - i dont want to post any links to outside companies
    good luck
    0 Not allowed!
  10. ☑ ORIGINAL POSTER #9
    Join Date
    Jul 2009
    Location
    Ontario Canada
    Posts
    78
    Watercrafts
    95 spx 96 WBII
    Thumbs Up
    Default
    so what im getting from that part number is that its the only shaft for that machine! that shaft shows 21" on a couple sites and Im seeing ebay as the place to go found one for $119
    thanks alot greyrider! appriciate it!
    0 Not allowed!
  11. #10
    Join Date
    Sep 2009
    Location
    hudson valley ny
    Posts
    180
    Watercrafts
    Thumbs Up
    Default
    i noticed the same thing - good luck
    anytime
    bobby
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 8
    Last Post: 08-31-10, 05:44 PM
  2. MSD Water Inj/ filter system,Enhancer, Impeller and Intake grate XP800
    By seadoonealdeal in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 08-08-10, 10:41 AM
  3. Islandia Impeller and Intake Grate
    By wingnut1961 in forum Modify!
    Last Post: 03-18-09, 11:18 PM
  4. intake grate and impeller
    By chevyzrule810 in forum 4Tec Performance Forum
    Last Post: 09-07-08, 01:50 AM
  5. intake grate and impeller
    By chevyzrule810 in forum Modify!
    Last Post: 09-06-08, 01:25 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
