Beeper........buzzer - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 1 of 1
  1. ☑ ORIGINAL POSTER #1
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Sea Doo 95, XP, SPX, GTX, SPI, XP, 97 Polaris Hurricane
    Thumbs Up
    Received: 36 Given: 3
    Default Beeper........buzzer
    No BEEPS
    bad buzzer, commonly go out on olded ski's moisture deterioration
    http://www.seadooforum.com/showthrea...920#post126920
    The sensor/sender is located between the spark plugs and when the engine reaches
    203-205 degrees, contacts/moves and grounds the wire to mpem, signaling the beeper.
    Grounding the sensor wire should produce the beeper/buzz. Periodically check it, ignition on.
    Seadooforum
    You can obtain a year-model SHOP MANUAL and learn everything about your ski.
    You can click on the link seadoowarehouse to veiw your skis parts and part numbers.
    then at right top click "parts by year, then by Model, then Section, place a number
    in box at left, scroll down to page bottom and click Add items to cart, and then the
    parts numbers will appear! then click the Clear Cart button after you obtain the #
    or you can order that part from our host! Your SHOP MANUAL will describe in detail
    how to maintain any part or remove and replace any part on your ski.
    NEW MEMBERS ARE ENCOURAGED TO JOIN AS PREMIUM MEMBERS SO AS
    TO HAVE ACCESS TO THE FORUM LIBRARY SHOP MANUALS AND SUPPORT!
    Please also to use the SEARCH function, as many subject questions have been already asked and answers many times!
    Beeper/buzzer is inside the handlebar pad where it can easily be heard. The wires
    are loomed down the center of the steering column then connect to the electrical
    wireing harness. A DETENT TOOL is available from Radio Shack for pushing the pins
    out of the plastic connector clip if you desire to pull the wires thru the column. Radio Shack Part # 274-223 for .093 pins.
    Note
    each wires orientation if you do that. Some people just connect a new beeper under
    the sterring consul as a easy location. Hope this Helps! Bills86e
    0 Not allowed!
  2. # ADS
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Where's the beeper?
    By timhood in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 09-09-11, 05:36 PM
  2. WTB: 96 GTX beeper/buzzer
    By wilbird287 in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 07-29-10, 06:26 PM
  3. That beeper has got to GO!!!!!!
    By Sako7STW in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 06-19-10, 10:45 AM
  4. Beeper
    By slowridin03 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-05-09, 11:10 AM
  5. xp beeper
    By ryanseadoo in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-29-08, 12:03 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
