97 xp charging problems - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    May 2008
    Location
    penfield ny
    Posts
    2
    Watercrafts
    1997 seedooxp
    Thumbs Up
    Received: 0 Given: 0
    Unhappy 97 xp charging problems
    i have a 97 see do xp ive been having charging problems , it starts fine 5-6 times then i get a clicking noise , i trickle charge the battery and its fine for another 5-6 starts and the same thing happens , i have a new battery in it so i no its not that
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    Here are some things to test and check on the charging system. When the engine is running, set your voltmeter for 20 VDC and put the leads on the correct terminal posts.(Red positive+, Black negitive-) With the engine running, you should be reading anywhere from 14.5 to 14.8 VDC. (typically this test is done at 5,000 rpms) This tells you your charging circuit is good. If the voltage is higher, the regulator is bad. If you’re not showing a charge and you've replaced the rectifier, you may want to do a test on the Magneto/stator/charging coil. If you’re not a premium member and you don't have access to a manual, this test will be hard to do without it.
    There are 2 fuses that protect the charging system. Check the 15 amp fuse in the MPEM and the 15 amp fuse between the solenoid and the MPEM.
    I hope this helps you out ...keep us posted.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    May 2008
    Location
    penfield ny
    Posts
    2
    Watercrafts
    1997 seedooxp
    Thumbs Up
    Default
    thanks ill check it out this weekend , the ski is 3 hrs from where i live , ill test and let u no what i come up with , i appreciate alot thanks again
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 2005 RXP Charging Problems
    By ace1948 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 05-20-08, 01:27 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
