96 XP key or lanyard? - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    May 2008
    Location
    The Colony, TX
    Posts
    7
    Watercrafts
    96 XP 98 GSX Limited
    Thumbs Up
    Received: 0 Given: 0
    Default 96 XP key or lanyard?
    I have a 96 XP. I have recently had a problem. When I plug in the key, sometimes it gives the usual 2 tones, sometimes it doesn't. I will be riding and sometimes if the key gets wiggled, the ski will die. I can take the key off, wiggle it around, etc... and I can restart the ski. My guess is, I will need to get it rekeyed.
    What do you think?
    Or is it likely that the lanyard would go bad?
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    I have found the post to go bad. First do this use soapy water and wash it clean. Use nothing on it, no gresw..no lube leave it dry. Here is some information to try;
    Safety Lanyard Switch Verification;
    If 2 short beeps are not heard when installing the safety lanyard, disconnect the switch wires.
    Safety lanyard removed;
    connect the test probes to switch Black and Black/Yellow wires. It’s an open circuit, there should be no continuity.
    Connect one test probe to the White/Gray wire and the other test probe to the switch terminal. Measure resistance, it should be “0” ohm. Connect one test probe to the Black wire and the other test probe to the switch ring. Measure resistance, it must be close to “0” ohm.
    Safety lanyard on switch; connect the probes to switch Black and Black /Yellow wires. Measure resistance, it must be “0” ohm.
    Timer Verification;
    The timer is integrated into the MPEM. Always confirm that the fuses are in good condition. To confirm operation of timer, remove the safety lanyard from switch. After 5 seconds delay, depress start/stop button once. The timer should stay on for 33 seconds (for example, the gauge(s) will be activated) and than turn off.
    Keep us posted on you progress.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    May 2008
    Location
    The Colony, TX
    Posts
    7
    Watercrafts
    Thumbs Up
    Default
    Thanks for you insight. I'll let you know how it goes.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. no beep when lanyard is connected
    By cdstegall in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 11-08-07, 11:28 AM
  2. 2000 Seadoo XP Limited, No Beep when connecting lanyard? Help?
    By Leviticus in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-30-07, 03:46 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
