Water inside engine???????? - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 12 of 12
  1. ☑ ORIGINAL POSTER #1
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    2003 seadoo GTI LE, 2006 wellcraft, harbor craft, 99 xpl
    Thumbs Up
    Received: 1 Given: 0
    Unhappy Water inside engine????????
    hey we are relatively new tho the seadoo we have owned ours for five years. We went to start it for the first time this season and it was making a very loud thunking noise. we ended up buying e new battery and putting it in that didnt help. So we took out the sprk plugs and found that our engine was full of water!!!!!!! NOT GOOD I DONT THINK??????
    0 Not allowed!
  2. # ADS
  3. #2
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default water....
    If you've ingested water into the engine, but it's still turning over, leave the spark plugs out and turn the engine over till all the water finishes spitting out. Then, take some of your 2 cycle oil and pour about 1 oz. in each cyclinder. Then, spin it over to get good lubrication. Then, put everthing back together and give it a try.
    The Rotax will take a lot, even being filled with water but you have to take immediate steps in getting the water out and lubricating before rust sets in.
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    Thumbs Up
    Default Thanks A Bunch
    we are going to do that right now
    0 Not allowed!
  5. ☑ ORIGINAL POSTER #4
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    Thumbs Up
    Default ?
    we gave it a try. and we think it needes some new spark plugs? but we dont really understand how the water got in ?????? its the first time that has happened??
    0 Not allowed!
  6. #5
    Junior Member
    Join Date
    May 2008
    Location
    Port St. Lucie, Florida
    Posts
    17
    Watercrafts
    1997 sea doo gsx and 1996 sea doo xp
    Thumbs Up
    Received: 0 Given: 0
    Default 1997 Sea Doo GSX
    I just had a similar problem. The doo ran fine until the last minute and it started acting like it ran out of fuel. I brought it home and filled it up but it still would not start. Fearing the salt water would destroy the engine I flushed it out without the engine running. I think this caused more problems. I have removed the plugs numerous times, cleaned, sprayed, blown, used starting fluid but still the engine will only sputter from time to time. I think there is water in the carbs but I do not know how to remove them. I can't even LOCATE them. HELP!!!!
    0 Not allowed!
  7. #6
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    Thumbs Up
    Default Water....
    Yes, you'll probably need to change them. Do you know how to check them for spark? Leave the plugs out of the plug holes and ground, at least one of them to the head using an "electricians" screwdriver or a small piece of wooden broom handle. If not, you'll experience the reason why mechanics hate working with coils.....40,000 volts is one hell of a jolt. When you turn the motor over, you will be looking for a blueish orange color spark. If you got spark and your able to blow out most, or all of the water, then lubricate, you may be able to get a start.
    Be patient in starting. The engine will need a lot of rotation (starting) to clean itself up. Do not use your starter for anymore than 30 seconds at a time. It will overheat and then you'll be buying a new one. Let it cool for a couple minutes, then try again. You can tell if your overheating by grabbing the ground wire of the battery. If it's hot, you've used the starter too much. If it's possible, after you get the new plugs, get the gas can that you use for your weed eater or chain saw and pour a "coke cap" full into each cylinder. Then try and start it. If it hits and runs for a second, then you will be looking at carb issues or water in the fuel or any combination of problems when water gets into your fuel system.
    There are a couple ways water can get into your engine. You can ingest water through the exhaust system. For instance, you roll it over upside down. When you right the engine, your suppose to roll it so that your exhaust manifold rolls to the direction that puts it under the motor, not on top. This is when the water will go into the cylinders.
    The water jacket, if breached by a gasket at the exhaust manifold, will also dump water into the combustion area. The tuned exhaust pipe is double lined, creating a passage for the water to circulate before going into the block of the engine. The preheat keeps thermal shock to a minimum.
    The water hose.....Never attach the water hose to the ski without it running. The procedure is to attach the hose to the flushout connection, start the motor, then turn on the water. The reason is for this is that pressure from your water jacket can enter into your combustion area from outside pressure. If you start the engine, the inside (combustion) pressure is greater than the outer (water jacket).
    Lastly, if you don't know where the carbs are, you may be best served to take your PWC to a certified OEM specialist.
    Louis
    0 Not allowed!
  8. #7
    Join Date
    May 2008
    Location
    maple valley washington
    Posts
    33
    Watercrafts
    96 gsx
    Thumbs Up
    Default 96 Gsx Wont Start
    Hello,
    My son just bought a used 96 gsx, it was in excellent condition, started perfectly, and we we're psyched to go skiing today, last week he went out and washed and waxed it up and hooked a hose to the rear without starting it. As expected there was water in the engine. I've drained the water, removed the plugs, sprayed a dry-out lube in it and turned it over several times with the plugs out. It has blown all the water out but..... we put new plugs back in and now it just goes clunk.... won't turn-over, i've been told to repeat this step several times by the dealer. I've done it a freaking 100 times today and nothing...... Can anyone give me any idea what to do next................"frustated" and it's 90 degrees here in seattle !
    0 Not allowed!
  9. #8
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    Thumbs Up
    Default Clunk?
    When you say it "just goes clunk"...what do you mean? When you hit the start button, does the starter turn say, a 1/4 turn then go "clunk"? Or, does it just go clunk the minute you hit the starter? With the plugs out, will it spin over?
    What kind of plugs did you replace with?
    Until you post with more info about your "clunk", make sure you pull the plugs, spray some "lithium" grease into the plug holes and turn it over by hand if necessary. Don't let the motor seize up on you.
    From the home of the new KC-45 Tanker,
    Mobile Alabama!
    0 Not allowed!
  10. ☑ ORIGINAL POSTER #9
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    Thumbs Up
    Red face Water
    thanks we are going out this morning to get some new sparkplugs. Im already praying.lol
    0 Not allowed!
  11. ☑ ORIGINAL POSTER #10
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    Thumbs Up
    Default Worked/Failed lol
    well we went and bought the sparkplugs it started up and ran good. we decided to put it in the water and give it a shot. I ran it for not three minites and the was a loud beep and the engine dropped RPMs. I putted my way back to the beach where we pulled it out and found the engine compartment full of water. I had noticed that when we first put it in the water it would not run at top RPMs it was bogging down? After drainig the water we found that our water cooling hose was not connected. It had been earlier when we ran it connected to the gardening hose??????? DID we blow up the engine???? if so how much cash?????
    0 Not allowed!
  12. #11
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    Thumbs Up
    Default Should be o.k....
    I don't think you blew the engine. If you did, you'd know. Their would be some knocking and engine noise that you'd never heard before.
    Fix the water line and try it again. You may have ingested some water...
    To make sure your crank and all is o.k., you can remove the shaft cover on the back of the pto side, remove the spark plugs and turn the engine over, counterclockwise, by hand. It should rotate smoothly. If it's clicking, or stopping before you make a complete revolution, then you may have engine damage.
    A new OEM refurbished engine for your ski runs somewhere around the neighborhood or $700-$1000 dollars, depending on where and what kind of warranty you get with it.
    Good luck.........
    0 Not allowed!
  13. ☑ ORIGINAL POSTER #12
    Senior Member
    Join Date
    May 2008
    Location
    Seattle Washington
    Posts
    153
    Watercrafts
    Thumbs Up
    Question Noise?????
    While in the water the engine went to have power and sounded horrible. after we took it out of the water and drained everything out and started it again it seemed to run fine at high RPM??????? Was that beep a warning that the engine is over heating????? ddi it go to half power by itself??
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 3 users browsing this thread. (0 members and 3 guests)
Similar Threads
  1. 96 GTX starting issue/Video inside.
    By 94silver in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-24-08, 12:38 PM
  2. Can I put too much water in my engine while flushing it?
    By scooper77515 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 04-23-08, 07:57 PM
  3. Got Water On Engine!!!
    By Valcig in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 03-31-08, 03:46 PM
  4. Seadoo 150 Speedster Inside
    By seadoofeed in forum Sea-Doo Videos
    Last Post: 02-25-08, 10:52 PM
  5. engine bogs/dies when in water, fine out of water
    By abinbigd in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 10-01-07, 09:05 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
