My entire crankcase is full of fuel - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Feb 2009
    Location
    montreal,canada
    Posts
    33
    Watercrafts
    1997 spx 1996 gsx(no motor,bought for the trailer) 1996 gtx, 197 hours on it
    Thumbs Up
    Received: 0 Given: 0
    Default My entire crankcase is full of fuel
    I rebuilt the carbs on my otherwise perfectly running 197.5 hr GTX this spring
    and to my surprise it RPM'd to 7000 rpm for the hole shot on take-off then settled to 5000 @30 mph. PTO plug fouled some what.
    I pulled the carbs to check the issue w/PTO carb and I found that the entire bottom of the motor was filled w/gas.I mean FILLED to OVERFLOWING!!
    I had to pull the balance shaft plug to get the gas out,but there is some left @lowest part of motor.I still smell like gas...mmmmm love it
    Do I have to pull the motor an tip it on end?I changed the fuel lines on the carbs.I don't thinlk that I mixed the lines up??
    Could I have really wrecked the motor?
    Don't throw tools.
    0 Not allowed!
  2. # ADS
  3. ☑ ORIGINAL POSTER #2
    Join Date
    Feb 2009
    Location
    montreal,canada
    Posts
    33
    Watercrafts
    Thumbs Up
    Default my entire crankcase is full of fuel
    BUT how do I get the rest out....Gas BAADDD FOR BALANCE SHAFT OIL.
    0 Not allowed!
  4. #3
    Senior Member
    Join Date
    May 2010
    Location
    North Florida
    Posts
    214
    Watercrafts
    2005 Sea-Doo RXP
    Thumbs Up
    Talking
    I say light a match.... But what the hell do I know??? I "do" throw tools!!!!!
    0 Not allowed!
  5. #4
    Dr Honda's Avatar
    Join Date
    Apr 2009
    Location
    Pittsburgh
    Posts
    18,136
    Watercrafts
    '00 Polaris Genesis '96 XP800 '02 Islandia 240 EFI
    Thumbs Up
    Received: 332 Given: 0
    Default
    Turn the fuel off, and crank the engine with the plugs out. You should be able to get most of the fuel out. Once it's clear, then drain the counter balance, and refill it with oil.
    Once you get new oil in the CB, then get it started to purge the rest of the oil out.
    Needless to say, you need to find out why the carbs are pouring fuel into the engine.
    when you did the carb rebuild... did you use aftermarket kits, or factory Mikini kits? If you used aftermarket kits... the diaphragms need replaced with mikuni parts. Some of the import kits (especially from Windrosa) have diaphragms that are too stiff, and the pin in the center is too long.
    Tony
    PM or post for help. Don't leave questions in my profile box. (i never check it)
    I'm not going to be able to do vinyl or carbs for a while. Starting my new job is taking a lot of time
    0 Not allowed!
  6. #5
    Chester's Avatar
    Join Date
    Nov 2008
    Location
    Surrey, BC Canada
    Posts
    1,198
    Watercrafts
    98 SXi Pro
    Thumbs Up
    Received: 7 Given: 4
    Default
    Check and replace the needles & seats in the carbs. The only way the crankcase fills with fuel is through a leaking needle & seat.
    Chester
    "A smooth sea never made a skillful mariner."
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Join Date
    Feb 2009
    Location
    montreal,canada
    Posts
    33
    Watercrafts
    Thumbs Up
    To all those interested,I miss routed one of the fuel lines on the side of the carbs,thereby pressure feeding the motor and blowing the needle off it's seat=free flowing gas through the ventury.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Fuel Gauge Always Showing FULL
    By Zonic2001 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 03-04-12, 04:04 PM
  2. Carb is Full of Goo from the old fuel lines!!!
    By Texas Guy in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 10-02-09, 04:48 PM
  3. 1997 speedster fuel leak- only when full
    By tfree10356 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-13-09, 03:31 PM
  4. Replies: 14
    Last Post: 01-02-09, 10:02 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
