Remove engine - jet pump - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email
Need OEM parts for your boat or PWC? Visit
Results 1 to 5 of 5
    Junior Member RogerC's Avatar
    Join Date
    Feb 2010
    2004 GTI LE RFI
    Thumbs Up
    Received: 0 Given: 0
    Unhappy Remove engine - jet pump
    Hi Guys
    I need to remove the engine from the doo (04 GTI LE RFI) to either repair / replace grankshaft or more than likely whole engine (cheaper option), I have a shop manual and it doesnt really say much about what to do if anything with the pump / shaft to take out the engine.
    What do i need to do with the jet pump /shaft to remove engine?
    If i dont move the mounts how likley is it that the alignment will be ok going back in?
    How accurate does the alignment need to be? How do i check this?
    Any help would be appreicated.
    0 Not allowed!
  2. # ADS
  3. #2
    Experienced Rider n3k0de's Avatar
    Join Date
    Jun 2009
    West Palm Beach
    1994 SPX // 1997 GSX // 2 x 1996 xp800 // 1998 Challenger 1800 // 1996 SPX
    Thumbs Up
    Received: 9 Given: 25
    I took some pictures with my cell phone that came out small but for what you can see is how i got my jet pump off... Took about 3 mins to setup and 30 second to pop the jet off..
    I had a pair of Retracable straps that I strap the back of the ski to the trailer.. and two hooks with holes.. I had to drill out the holes bigger for the steering screws to fit into them.
    Hooked the strapes to a fence pole. Its strong and wont bend.
    This is a good way to get it pump out even.
    side view.. You can see how the hooks are in..
    The harest part if you are doing it yourself is locking the trailer tires i used tire chucks or stops from a camper my dad had... and if you press your back on lets say the fence and put your feet on the ski you have more control and the ski wont move back when you crank the straps....
    I dunno, this worked for me.. The pump hasnt came out for about 10 years so it was a lucky shot for me?
    0 Not allowed!
  4. #3
    Experienced Rider
    Join Date
    Jan 2010
    1995 GTX 1997 Challenger
    Thumbs Up
    Received: 4 Given: 0
    That looks like a good idea with the fence post, I have just tugged and tugged and used a 2X4 about 3ft to push from side to side breaking loose the seal a little at a time. The spline driveshaft prevents a lot of twisting so however you can pull this is what it takes.
    0 Not allowed!
  5. #4
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Deep South
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default Engine...
    The engine will have shims under the mounts. Mark those shims to their locations. You can use a sharpie to make north/south marks to help to re-align the motor too.
    Once you do this, you will be able to put it back in the way you took it out. Although you want to be aligned well, the design of the shaft has a rounded spline type fit. This is so it can take up a small amount of mis-alignment.
    But, you do want it as close as possible...
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  6. #5
    seadooya's Avatar
    Join Date
    Nov 2009
    so-cal foo
    97 XP..building motor, 96xp w/97gsx guts, 98 sportster 1800, 97gti...$200 buks,
    Thumbs Up
    Received: 2 Given: 0
    Default pump removal
    your pump RogerC will take 5 minutes to remove. Undo the steering cable and reverse bucket cable(if applicable) along with the VTS rod(if applicable), then remove the 4-17mm nuts against the hull, after that, pull and she'll pop right off. The reason the previous poster had to go thru all that, is because prior to the "neoprene" seal, they siliconed the pump to the hull...
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. oil ratio if remove the pump?
    By HappyMongo in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-01-11, 06:49 PM
  2. About to remove engine in speedster HELP
    By wittock08 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 04-04-09, 08:25 PM
  3. 99 GTI need to remove water pump assembly, which bolts? WITH PICS
    By 97SPX in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 10-23-08, 08:06 PM
  4. to remove the Oil injection system or not to remove?
    By mark younggren in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 09-05-07, 12:05 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
