Merc oil blocker plate - 2 to choose - which one?? - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 9 of 9
  1. ☑ ORIGINAL POSTER #1
    Join Date
    Jan 2010
    Location
    TX
    Posts
    31
    Watercrafts
    2002 yamaha fx140 2000 seadoo challenger 2000
    Thumbs Up
    Received: 0 Given: 0
    Default Merc oil blocker plate - 2 to choose - which one??
    Hi
    Was just to dealer to pick up blocker plate to remove oil injection for 210 merc jetdrive
    The blocker they had is about 5 1/2 inches long - looks like you have to take out driven shaft before inserting - has o ring
    then we found another in the computer that looks more like the right one - that is a lot shorter and looks like you retain the driven shaft and this has a short sleeve that goes over the end when installed.
    ANyone done this and know which one is best?
    Don't you think it is bad to leave shaft in the engine with no load (oil pump gone) at all - it may have more play and slop and cause problems later.. ??
    thanks in advance
    Andy
    0 Not allowed!
  2. # ADS
  3. #2
    Junior Member
    Join Date
    Feb 2010
    Location
    portland or
    Posts
    4
    Watercrafts
    hydrostream valero alumaweld formula vee sea ray pachanga
    Thumbs Up
    Default the pn you need
    you need pn 43453 for the pump block off and 2 shorter screws and a 1/4 inch pipe plug to remove the injection..
    and the nipple on the end of the block off supports a brass bushing in the front half and block that if not supported have a tendancey to fall into the intake path and blow up motors
    the check valve on the block next to the poppet valve also needs removed and plugged offwit a pipe plug
    if you left the drive shaft it would soon find its way into the cylinder via a big bang...... so it comes out. the shorter block off is for 3.0L outboards
    Last edited by stream2.5; 02-05-10 at 02:18 PM. Reason: typed wtong pn 43453 not 43454
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Join Date
    Jan 2010
    Location
    TX
    Posts
    31
    Watercrafts
    Thumbs Up
    Default thanks - more help
    The part number I have here is quicksilver # 43453 - is this not the correct one?
    receipt says AA708 Plug
    thanks
    Andy
    0 Not allowed!
  5. #4
    Junior Member
    Join Date
    Feb 2010
    Location
    portland or
    Posts
    4
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by andyak View Post
    thanks
    Andy
    yep i typo'd... 43453 is correct
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Join Date
    Jan 2010
    Location
    TX
    Posts
    31
    Watercrafts
    Thumbs Up
    Default
    assuming 43453 is correct - Search for 43454 came up with a terminal block - so I think 43453 is right -
    The shaft has one side that is flat - does that side go in facing downward?
    is it safer to leave the oil pump on and just loop on engine tank back to itself?
    Thanks again,
    Andy
    0 Not allowed!
  7. #6
    Junior Member
    Join Date
    Feb 2010
    Location
    portland or
    Posts
    4
    Watercrafts
    Thumbs Up
    Default
    flat side out nipple in after removing pump and gear assembly, either leave the injection, or remove it entirely... no questions then if you sell the boat as the tank and all related parts are removed not just by passed
    and yes 43453 is 100% correct... i miss typed the number.. on a netbook with fat fingers you will also need to disconnect the rotational sensor and oil injection related electronics... or you will get an alarm from the ecm
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Join Date
    Jan 2010
    Location
    TX
    Posts
    31
    Watercrafts
    Thumbs Up
    Default
    thanks - yeah I know the nipple goes in - the shaft itself with the nipple has a flat side to the round shaft - I assume that goes toward the crank gear so it doesnt rub. so was just askin which way the flat side of shaft faces as you insert it in.
    I know about the oil level alarm for the engine tank - didnt know there was a rotational sensor - any hint on what to disconnect there.
    I really appreciate the help man!
    Best,
    Andy
    0 Not allowed!
  9. ☑ ORIGINAL POSTER #8
    Join Date
    Jan 2010
    Location
    TX
    Posts
    31
    Watercrafts
    Thumbs Up
    Default
    Hey finally found some instructions - good ones here:
    http://bassinhound.net/boating/inject/index.html
    Best,
    Andy
    0 Not allowed!
  10. #9
    Junior Member
    Join Date
    Feb 2010
    Location
    portland or
    Posts
    4
    Watercrafts
    Thumbs Up
    Default
    will only go in 1 way and fit the holes to secure it. flat to gear, the rotational sensor un hooks rom the blue wire viia quick dosconnect and from a screw down ground wire on the top o the block.. it resides on the block above the pump, its a magnetic sensor
    remove the pump, resovior tank, lines and the check valve on the bottom of the block the pressure line hooked to and install a pipe plug where the check valve was. simple as that.. then drain all fuel. mix 40-50:1 and refill tank with premix, purge fuel line to motor... go boat....
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. R&D Extender Plate on E-bay...
    By LegalizeIt in forum Buy/Sell/Trade Sea-Doo Related
    Last Post: 09-11-09, 12:01 PM
  2. GTX Ride Plate
    By DougDove in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 03-23-09, 10:22 PM
  3. Throttle plate????
    By Chrisca74 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 02-21-09, 01:32 PM
  4. gtx riding plate
    By terryens in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-03-09, 03:56 PM
  5. ride plate
    By spunkyone in forum Non-Seadoo PWC Talk
    Last Post: 11-27-08, 10:11 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
