beeping sound - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 9 of 9
Thread: beeping sound
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jan 2010
    Location
    menifee
    Posts
    5
    Watercrafts
    95 seadoo spi 94 seadoo xp
    Thumbs Up
    Received: 0 Given: 0
    Default beeping sound
    so my wife's 95 seadoo spi makes a horrible beeping sound after riding about 15 mins. the story goes: we were riding around the local lake one day her seadoo made a horrible beeping sound so she jump off thinking it was going to explode ( yes it was funny ). i got her back on and towed her to shore. we had sucked up a bag around the impeller shaft. took the bag off, rode around one more time then went home. every thing was good. the next time at the lake her seadoo made a load clanking sound and then lost all power. would barely go forward. so i did some research and found that the wear ring was most likely the problem. sure enough it was completely wasted. so i replaced it. in the process i broke one of the plastic hose nipples and replaced it with a quarter in metal pipe. now the things hauls butt, but after a little bit of riding it starts beeping at her. what should i do?
    thank you
    0 Not allowed!
  2. # ADS
  3. #2
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Sea Doo 95, XP, SPX, GTX, SPI, XP, 97 Polaris Hurricane
    Thumbs Up
    Received: 36 Given: 3
    Default
    You should remove the sand from the hose that exits starboardside ski rear as
    that clog will overheat the engine and steam will start coming out the pisser.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jan 2010
    Location
    menifee
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    I flush my system everytime i am done. wouldnt that get the sand out if there was some there? i am new to this please forgive me
    0 Not allowed!
  5. #4
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Thumbs Up
    Default
    No, It would not. It would just continue to backflush out the jetpump venturi. It
    is between the backflush hose and exhaust restrictor/hose connection at the
    rear pipe. You may even need to drill the restrictor with a 9/32 bit. HTH
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Junior Member
    Join Date
    Jan 2010
    Location
    menifee
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    is there a web page or some thing that would show me exactly where and what to drill. where is the restrictor
    0 Not allowed!
  7. #6
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Bills86e View Post
    http://partsfinder.onlinemicrofiche....&B=13&Action=O
    item 2 is the hose
    item 8 is a connector/restrictor
    If circulatory water gets its flow estopped
    around 190 degrees the temp sensor will actuate the overheat beeper,
    at 212 degrees water turns to steam.
    Then metals expand and engine siezure results.
    The oil tank also has a sensor that can actuate lite/beeper for low oil. item 25
    http://partsfinder.onlinemicrofiche....&B=15&Action=O
    0 Not allowed!
  8. ☑ ORIGINAL POSTER #7
    Junior Member
    Join Date
    Jan 2010
    Location
    menifee
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    i will play with this on my next day off.
    the other thing i was going to ask about is the fuel lines. i was told that if i have the gray fuel lines they need to be replaced.... is this true
    thanks for all your help
    0 Not allowed!
  9. #8
    Bills86e's Avatar
    Join Date
    Feb 2009
    Location
    TampaBay, Florida
    Posts
    3,297
    Watercrafts
    Thumbs Up
    Default
    Yes. The grey lines internally deteriorate. I suggest: To REPLACE FUEL LINES
    First, remove the negative battery cable from battery then siphon and empty any gas from tank.
    On 587's, 657's, & 717 skis, cut the new 1/4"I.S.dia. gas line one piece 12" long, two pieces 24" long, two pieces 60" long.
    Remove the fuel selector switch by pulling the center plug of the fuel dial with a needle, and remove the phillips #2 screw,
    and wiggle & pull until the knob pulls off. Then unscrew the 22mm plastic nut, washer, and push it thru the hull, into interior
    compartment. Next, under steering and in front compartment, useing a 10mm ratchet wrench, remove the nut on top of the separator
    filter's bracket to free it. Cut all the old fuel lines about 2" away from each part, and set aside. On top of the fuel tank is
    a four line bafel top. Look for the vent line and pull that up and off, it probly will come easily. Make a mental note of the
    zip ties to the lines as you will tie everything secure from bouncing around when you are done. Next, cut the three remaing lines
    2" above the bafel, and pull them up and off as well. Next, undo the two rubber strapes holding the gas tank down in its position,
    then unclip the fuel bafel two wire electrical connector. Unhook starboard oil tank strap. At this point you could attempt removal of the bafel from tank,
    or wait and grab the emty gas tank from frontside and remove from the ski thru the compartment hatch, and you mat be able to manuver
    it out along with the tank as a unit. Remove the bafel by loosening the lower gear clamp and pulling the bafel up. A circuit board and
    a float with a magnet on it is inside the bafel and sends a signal to the MPEM and gauge as to the fuel level. The bottom of the bafel
    has a clip/screen, you should remove and clean, and look at the short and full lenth fuel straw in there. The one that is at bottom
    where the clip/screen is, is the RESERVE. The one thats about 1 1/2" short is the ON straw. Mark the On & Reserve spigot tube at the
    top of the bafel on each tube. Even draw a circle front of the tank bafel with a majick marker of the two wires and four tubes. Mark the O & R on
    your drawing, the two other tubes, one is a vent line connection, the other is the fuel returm line from carb & returns unused fuel to tank tube.
    Remove the Carburator Air Box to gain access and remove the supply and return fuel lines from the carbs, and discard them. Next, clean
    out the fuel tank (use a rag swab on a slim rod) Clean the fuel bafel, disassemble the fuel separator bowl and filter and square O-ring, clean and reassemble tightly.
    Please use a marine grade or lines from fuellines.com.
    0 Not allowed!
  10. ☑ ORIGINAL POSTER #9
    Junior Member
    Join Date
    Jan 2010
    Location
    menifee
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    you are " THE MAN".
    thank you
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Beeping when snapping on key
    By Jono6716 in forum Non-Seadoo PWC Talk
    Last Post: 08-14-08, 08:56 AM
  2. Beeping on start??
    By Ron1z in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-10-08, 05:11 PM
  3. 1995 HX beeping
    By BrntWS6 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-10-08, 10:25 AM
  4. Beeping
    By ejensen1 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-12-08, 08:37 PM
  5. Utopia - Beeping
    Last Post: 06-30-08, 05:23 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
