How a Two Stroke Engine Works - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 1 of 1
  1. ☑ ORIGINAL POSTER #1
    Member RX951's Avatar
    Join Date
    Jul 2008
    Location
    League City
    Posts
    75
    Watercrafts
    2000 GP1200R (GPRXP) 2006 RXP
    Thumbs Up
    Received: 4 Given: 0
    Lightbulb How a Two Stroke Engine Works
    For those newbies out there that was still learning about internal combustion engines, here is information on how a two-stroke engine works.
    :arrow: The two-stroke engine consists of only three mobile parts: Piston, connecting rod and crankshaft
    :idea: The first two-stroke engine was a gas engine invented and built by Etienne Lenoir in 1860.
    :idea: A two-stroke diesel engine was built by Dugald Clark in 1878
    Mode of operation of the Two-Stroke engine
    1st Stroke
    At the point where the spark plug fires, fuel and air in the cylinder have been compressed, and when the spark plug fires the mixture ignites.
    The resulting forces drives the piston downward. As the piston moves downward, it is compressing the air/fuel mixture in the crankcase.
    As the piston approaches the bottom of its stroke, the exhaust port is uncovered. The pressure in the cylinder drives most of the exhaust gases (but not all) out of cylinder.
    note:
    As the piston finally bottoms out, the intake port is uncovered. The piston's movement has pressurized the mixture in the crankcase, so it rushes into the cylinder, displacing the remaining exhaust gases and filling the cylinder with a fresh charge of fuel.
    2nd stroke
    Now the momentum in the crankshaft starts driving the piston back toward the spark plug for the compression stroke.
    As the air/fuel mixture in the piston is compressed, a vacuum is created in the crankcase. This vacuum opens the reed valve and sucks air/fuel/oil in from the carburetor. Once the piston makes it to the end of the compression stroke, the spark plug fires again to repeat the cycle.
    2000 Stage II GP1200R ~ 76.7 / 7280 rpm [GPRXP in progress]
    2000 GPRXP ~ 83.6 / 7900 rpm
    2006 Stock RXP ~ 67.7 mph
    Pics~Pics & Mods~ / Keep the 2-Strokes Alive !
    0 Not allowed!
  2. # ADS
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Replies: 8
    Last Post: 12-26-11, 01:12 AM
  2. Shaft RPM vs Engine RPM on a 787 2 stroke
    By patman25 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-15-10, 04:02 PM
  3. How a 4 stroke works
    By seadoo GTS 1993 in forum Non-Seadoo PWC Talk
    Last Post: 06-01-09, 03:32 PM
  4. Replies: 19
    Last Post: 04-17-08, 02:40 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
