tune-up - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
Thread: tune-up
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Oct 2009
    Location
    south florida
    Posts
    27
    Watercrafts
    98 sportster 1800
    Thumbs Up
    Received: 0 Given: 0
    Default tune-up
    Okay so planning on doing a tune-up this week. I like to do everything at once, Im the "while your in there you might as well" type of guy.
    My list:
    Fuel filter - Do i get a pair of the $20 filters from the local speedshop?
    Oil filter - Do i get a pair of the $20 filters from the local speedshop?
    Spark plugs-NGK BR8ES, correct?
    Carb Rebuild - Ive never torn down a carb before, Do i just get a "rebuild kit"?
    I've done almost all of my auto mechanic work (turbos, exhaust, efi tuning, etc), so im assuming i dont need any special tools.
    Is there anything else I should at the same time?
    Thanks in advance
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    For the filters, use replacements like old ones from Auto Zone...only a few bucks each. Be sure the mesh isn't too fine to block the flow. You could just clean the carbs being careful, you shouldn't need to use a rebuild kit. The NGK BR8ES plugs should be gaped to .021"-024"
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Oct 2009
    Location
    south florida
    Posts
    27
    Watercrafts
    98 sportster 1800
    Thumbs Up
    Default
    Quote Originally Posted by kustomkarl View Post
    Karl
    Do i need to use the stock oil filter? or does autozone have a replacement also?
    Cleaning carbs? Is that just spraying some of the sea-doo lube thru throttle body?
    thanks again
    0 Not allowed!
  5. #4
    Banned
    Join Date
    May 2008
    Location
    inland empire, CA
    Posts
    5,084
    Watercrafts
    99' Seadoo Speedster
    Thumbs Up
    Received: 7 Given: 0
    Default
    break the carbs down, and spray away, then re-assemble. For oil filter, never changed those, and for gas filters, i use the ones from motorcycle/dirtbike shop..glass/clear ones, for 2-buks.
    0 Not allowed!
  6. #5
    Member DnE1800twin's Avatar
    Join Date
    Oct 2009
    Location
    Ocala, FL
    Posts
    99
    Watercrafts
    '97 Seadoo Challenger 1800 24Ft personal submarine powerd by 2 18hp electric motors.
    Thumbs Up
    Default
    Ive opened the carbs up several times and found that when they run for a while the gas gets to the o-rings and they swell. If they swell up too much you would prolly need a kit to replace them as they are very difficult to get lined up in the groove when your ready for re-assembly. Ive learned alot in these threads and thats the one thing I dont see many ppl talking about.
    Otherwise the carbs are simple and easy to clean.
    I havent changed my oil filters as of yet either but the fuel filters are easy to come by at the parts store for just a few buks.
    Karl knows better than I but I thought I read somewhere that the plugs should be BR9's.
    I too am a car guy but I havent found the need as of yet (other than a pop-off tester) for any special tools.
    good luck and these guys are always here when ya need em.
    0 Not allowed!
  7. #6
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,852
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default Walmart?
    Karl
    Do not use paper filters from an auto parts supplier. KustomKarl has specifically said "mesh" so I'm sure he's saying the same.
    Walmart actually has marine fuel filters that you can buy and replace your old one with. It's a filter that seperates and can be cleaned and replaced if necessary. They also have extra filters, so I'd pick a few of them up to. If they don't have them in your local boat section of your sporting goods section, you can go online to Walmarts and order direct from their online store. It will be delivered to your local store. Any other problems, let me know and I'll get you the SKU and you can have the manager order it for you.
    If your gentle with the carbs, you should be able to open, inspect and clean without replacing anything for your first go round at least. This will let you familarize yourself with the internal parts before doing a full rebuild. The only parts you have to be very careful with is, do not bend your lever or spring that controls your needle valve. They are floatless carbs, so not a lot inside of them. I use carb cleaner or brake cleaner and the little red hose that comes with it, to spray through the internal porting to make sure nothing is blocked up............ good luck!
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 2002 gti tune pipe
    By scar3511 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 07-14-09, 11:04 AM
  2. tune pipe
    Last Post: 07-06-09, 11:50 PM
  3. tune up spx seadoo 2yr shut down
    By mikeymuy in forum Non-Seadoo PWC Talk
    Last Post: 07-02-09, 02:09 PM
  4. spx no use in two years tune up?
    By mikeymuy in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-02-09, 11:15 AM
  5. 1993 Sp carburetor tune-up
    By SP RACER in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-16-07, 12:00 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
