Changing to Synthetic Oil ? - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 13 of 13
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Aug 2009
    Location
    NY - Upstate
    Posts
    9
    Watercrafts
    16" Old Town Canoe, Penobscot 12" Gamefisher Fishing Boat 2000 Islandia
    Thumbs Up
    Received: 0 Given: 0
    Default Changing to Synthetic Oil ?
    My 2000 Islandia has used Quicksilver premium for the past many years but now I'm considering Pennziol synthetic because of the reduced cost, about half the price. I've read a few articles that say it won't make much of a difference in motors that were built past 1980'ish.
    Has anyone had experience with this?
    0 Not allowed!
  2. # ADS
  3. #2
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Okotoks Alberta, Canada
    Posts
    1,012
    Watercrafts
    2006 Yamaha AR230 HO 320hp
    Thumbs Up
    Received: 4 Given: 0
    Default
    If it's a good quality TC-W3 oil you should be fine. My little 200 Optimax only burns about a gallon or a gallon and a half a season, so I've never worried about the price. How many hours are you putting on a season that's it's a problem?
    Aaron
    Looking for parts for your Doo?? Click HERE
    Find your Mercury M-2 motor and pump parts here!
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Aug 2009
    Location
    NY - Upstate
    Posts
    9
    Watercrafts
    Thumbs Up
    Default Synthetic oil
    I just got the boat a few months ago and am getting a feel for the oil/gas usage and am trying to save a few buck where I can. I use about a gallon of oil per tank of gas and use about a 1/3 tank per weekend. The Quicksilver is about $28 and a tank of gas is about $150. If I use the Penzzoil, I can also get a 12 pak and a bag of chips at each fill up for the same price.
    0 Not allowed!
  5. #4
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    1,012
    Watercrafts
    Thumbs Up
    Default
    A gallon of oil a tank !!!!!!!!
    The Mercury is set-up to run at 100:1 at idle and 50:1 at full throttle. Even if you started the boat at wide open and kept it there the entire time you should not be burning that much oil. Are you premixing, or using the injection system? If you're using the injection system, check to see if the rod from the throttle to the oil pump is still connected. I have a feeling it has come off or is timed wrong.
    With average use a gallon of oil should last between four and nine tanks of fuel depending on throttle opening.
    Aaron
    0 Not allowed!
  6. #5
    Join Date
    Apr 2008
    Location
    tyler tx
    Posts
    50
    Watercrafts
    2002 seadoo 1800 challenger
    Thumbs Up
    Default
    I did this switch because of the cheaper price as well. But, I ended up switching back because the penzoil smokes allot more. No difference in performance but allot more smoke with the penzoil.
    0 Not allowed!
  7. #6
    Member Adam X20's Avatar
    Join Date
    Apr 2010
    Location
    Toronto,ON Canada
    Posts
    46
    Watercrafts
    2003 Challenger X 20 Merc Opti 250
    Thumbs Up
    Default
    Any Beefs against changing to Amsoil HPI ????
    Or Advice doing the change?
    Can you Mix brands at change time? (Merc 5% almost empty/Amsoil95%)
    0 Not allowed!
  8. #7
    Join Date
    Apr 2010
    Location
    Toronto,ON Canada
    Posts
    46
    Watercrafts
    Thumbs Up
    Default
    0 Not allowed!
  9. #8
    Join Date
    Apr 2010
    Location
    Toronto,ON Canada
    Posts
    46
    Watercrafts
    Thumbs Up
    Default
    0 Not allowed!
  10. #9
    Experienced Rider
    Join Date
    Apr 2010
    Location
    Spokane
    Posts
    461
    Watercrafts
    97GSX/Rotax 787, 96XP/Rotax 787, sold: 2001 C2K/Mercury 240EFI, now: Tige 24Ve/PCM 5.7L V8
    Thumbs Up
    Received: 7 Given: 0
    Default A gallon of oil per tank is INSANE. Something is horribly wrong.
    Must be a TON of smoke following you around on the water. Yikes!
    I'd recommend fixing whatever is wrong with your engine, then sticking with Mercury Premium Plus. As noted by another respondent, it smokes a lot less than other brands and the exhaust isn't as smelly either.
    Rule of thumb: Always buy the best lubricants you can afford. That's an expensive engine you're protecting....
    0 Not allowed!
  11. #10
    Join Date
    Apr 2010
    Location
    Toronto,ON Canada
    Posts
    46
    Watercrafts
    Thumbs Up
    Default
    Mine runs fine, the other guys (rdkimmel) is the burner....
    My question was leading to Amsoil being a full synthetic (not blend like Merc)
    being superior?
    No $$$ Savings
    What is BEST?
    0 Not allowed!
  12. #11
    Experienced Rider
    Join Date
    Apr 2010
    Location
    Spokane
    Posts
    461
    Watercrafts
    Thumbs Up
    Default I use AMSOil in my Rotax 2-stroke engines, but...
    ...in the Mercury 240EFI I continue to use Mercury/Quicksilver Premium Plus. As you note, there's really no cost savings so that's not a motivation. I also talked to someone at AMSOil and while they aggressively recommend their products for almost every engine you can think of, they are "cautious" and "cagey" when it comes to the 2.5L and 3.0L Mercury engines. That really made me think.
    I have tried other marine 2-stroke oils and they smoked and stank much more than PP. Finally, while I know manufacturers want to sell you their inflated and expensive products, Mercury knows their engines better than anyone and PP is what they recommend. Not a deal-maker but definitely a consideration.
    Since there is no financial incentive to go elsewhere, and there are definite smoke and smell incentives to stick with PP, and there just might possibly be some additive advantages to the Mercury product, I've chosen to stick with PP.
    0 Not allowed!
  13. #12
    Junior Member
    Join Date
    May 2009
    Location
    Palm Desert, CA
    Posts
    18
    Watercrafts
    2008 Challenger 180 SE: Solas Concord 14-19, OEM/Impros 12-20 Audio - stock radio - Boss D600.2
    Thumbs Up
    Default "do not use synthetic oil" 4-tec
    I use only synthetic oil in all my stuff after break-in, but as far as the boat, the owners manual is specific, and references the super charger clutch as the reason why. We are pushing well over 200Hp out of these 3 cylinder, 1.5L why take a chance?
    0 Not allowed!
  14. #13
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default Scic..?
    I read an article last fall where they "BRP" have actually come out with a synthetic oil that you can now run in your SC/SCIC engines. I'm sure it's got to be the newer models with the revised Stainless washers, no ceramic...
    There is a thread in the forum somewhere because I had to validate what the member said. He sent me a link to the site from BRP that listed it, so yeah, you can use synthetic in them now. I'd just be sure to check with a BRP certified mechanci first. I'll see if I can find that old thread....
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. non synthetic to synthetic
    By SheaMolt in forum Non-Seadoo PWC Talk
    Last Post: 06-05-09, 06:23 PM
  2. No more XPS Synthetic!!
    By donlynn05 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-19-09, 09:01 AM
  3. Synthetic oil
    By glen young in forum Non-Seadoo PWC Talk
    Last Post: 07-19-08, 11:18 PM
  4. How to tell if my Sea Doo has synthetic oil
    By mobjack75 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-02-08, 12:07 PM
  5. XP-s synthetic oil
    By battscrew in forum Non-Seadoo PWC Talk
    Last Post: 05-26-08, 09:04 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
