2001 utopia 185 - no low speed thrust - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jul 2009
    Location
    Michigan
    Posts
    2
    Thumbs Up
    Received: 0 Given: 0
    Cool 2001 utopia 185 - no low speed thrust
    I have the Optimax 200 hp engine. it is supposed to thrust at low speed when you turn all the way left or right...which helps maneuver at low speeds. Right now, I get nothing. Overall acceleration is fine, but I miss the low speed thrust......
    0 Not allowed!
  2. # ADS
  3. #2
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Okotoks Alberta, Canada
    Posts
    1,012
    Watercrafts
    2006 Yamaha AR230 HO 320hp
    Thumbs Up
    Received: 4 Given: 0
    Default
    It's your low speed steering assist. There is a pickup mounted on the steering column, and a magnet at either side. When the pickup on the column gets close enough to the magnet on either side, it sends a signal to the ECM to bump up the RPM.
    When I picked up my U-boat only one side worked. Turned out to just be an adjustment. You need to remove the instrument panel to gain access to the column. Start by trying to adjust the tolerances a bit tighter and see if that helps.
    Aaron
    Looking for parts for your Doo?? Click HERE
    Find your Mercury M-2 motor and pump parts here!
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jul 2009
    Location
    Michigan
    Posts
    2
    Thumbs Up
    Default Thanks....
    This sounds like it is the problem. Appreciate the quick response.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Looking at a 2001 Utopia
    By kevspyder in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 09-28-09, 02:02 AM
  2. 'nuther newbie - 2001 Utopia 185
    By jshaley in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 07-08-09, 11:03 PM
  3. 2001 utopia 185 with engine problem
    By 4kelly in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 08-19-08, 10:06 PM
  4. Wanted: 240 EFI Merc for 2001 Utopia 205
    By rpritcha in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 07-30-08, 07:49 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
