Oil gauge warning on Merc 240 M2.... 02 Islandia - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 3 of 3
    Junior Member
    Join Date
    Feb 2009
    New Mexico
    Thumbs Up
    Received: 0 Given: 0
    Default Oil gauge warning on Merc 240 M2.... 02 Islandia
    Ok gang, first off, I am not an engine mechanic. I can do just about everything else in the world but a mechanic I cannot claim. Neighbor (awesome mechanic) helping solve probs. Oil warning light in fuel gauge went off couple weeks ago. We have filled bottom tank and engine mounted tank is filling....... but slowly. Can't find a leak anywhere yet in any lines, but noticed the line coming off the engine mounted tank a tee. One goes to the engine mounted tank, the other to???? and the third tee has a short line appx 3 inches long that just stops. In the specs, we found two pics, one that shows this tee with a yellow plug in it and another showing it as a vent. Is this supposed to be an "open vent" or is it supposed to be plugged? Seems if it is "open" it would cause air which would screw up the pressurized system???? Maybe....... or not.
    Aaron, where are you buddy
    Supposed to leave Fri am for the lake and can't fathom not having the boat!!!
    0 Not allowed!
  2. # ADS
  3. #2
    Senior Member seadoodude1's Avatar
    Join Date
    Oct 2008
    Cypress, TX
    1998 Seadoo GSXL & 2000 Seadoo Challenger 2000
    Thumbs Up
    Received: 1 Given: 0
    I have same setup on my challenger but it's at storage. I'm guessing, but that one line is probably a vent with check valve. Other line goes to crankcase for a pulse to pressurize system. Check valve would let air in on vacum stroke and close vent on pressure stroke, thus pressurizing system.
    0 Not allowed!
  4. #3
    Experienced Rider
    Join Date
    Jun 2008
    Mckinney, Texas
    2000 Seadoo Speedster Merc V6 240 EFI
    Thumbs Up
    you may want to loosen the lid on the engine mounted reservoir and run it on the hose till you fill the top tank or till you see it running out of the cap and tighten the cap back to perhaps eliminate any possible bubbles in the line that could be causing the problem.. \
    Rookie101 is the Merc guru, he's sure to chime in
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 03 gtx oil warning
    By everley in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 06-08-09, 10:35 AM
  2. GAS Gauge (How to check Fuel Gauge is working?) 97 SPX
    By Johnson8537 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 10-05-08, 04:28 PM
  3. Fuel gauge and speedo gauge problem
    By ronald in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-10-08, 11:08 AM
  4. 2003 Islandia w/250 Merc opti Questions please
    By froggie76 in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 09-08-08, 06:40 PM
  5. '93 SPX warning beeper? what is it?
    By kmack in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 06-29-08, 03:44 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
