Water in Hull of 2001 GTX - Seadoo Forums
Results 1 to 7 of 7
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jun 2009
    Location
    Katy, TX
    Posts
    2
    Watercrafts
    2001 Sea Doo GTI, 2001 Sea Doo GTX
    Thumbs Up
    Received: 0 Given: 0
    Default Water in Hull of 2001 GTX
    Hose hook up doesnt show any water into hull, but leaving in water for the weekend and it fills up. Plugs are in. When trailered water doesnt exit hull until plugs are pulled. Any suggestions?
    0 Not allowed!
  2. # ADS
  3. #2
    Senior Member
    Join Date
    May 2009
    Location
    Lindenhurst, NY
    Posts
    174
    Watercrafts
    95 XP
    Thumbs Up
    Default
    Coming in through the pump somewhere probably
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jun 2009
    Location
    Katy, TX
    Posts
    2
    Watercrafts
    Thumbs Up
    Default
    Wouldnt it fill up when connected to hose if it were the pump?
    0 Not allowed!
  5. #4
    SeadooForum Pro
    Join Date
    Jun 2008
    Location
    Canada
    Posts
    1,313
    Thumbs Up
    Default
    check the carbon ring seal.....
    0 Not allowed!
  6. #5
    Junior Member
    Join Date
    Jun 2009
    Location
    New Hampshire
    Posts
    1
    Watercrafts
    Seadoo GTI DI Larson SEI 174
    Thumbs Up
    Default
    2002 GTX DI: I just put jet ski into the water from winter storage. Started, ran fine but when I docked I heard water gurgling(from inside back) in. I beach it as best I could but have 6 inches of water in hull. Need to pump out and get back on trailer so I can find leak. It leaked/gurgled more when my weight was on the back end pushing it deeper into the water. All hoses seem to be tie wrapped tight.
    Any ideas where to start? Pictures would be nice as I am a Newbie.
    0 Not allowed!
  7. #6
    Experienced Rider JJinSC's Avatar
    Join Date
    May 2009
    Location
    SC
    Posts
    936
    Watercrafts
    1997 Sea-doo XP
    Thumbs Up
    Received: 8 Given: 1
    Default
    Quote Originally Posted by tinkerbell View Post
    This may not be it since you said no water exits until drain plugs are pulled, but it is easy to check. Check the o-rings on your drain plugs. They dry, crack and sometimes even fall off. You will have a slow leak when left in the water if they are not in good shape.
    0 Not allowed!
  8. #7
    Senior Member
    Join Date
    May 2009
    Location
    Lindenhurst, NY
    Posts
    174
    Watercrafts
    95 XP
    Thumbs Up
    Default
    Not really. If some seal in the pump is leaking it will leak when you are going slow or at a stop sitting in the water.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 95 hx water in hull
    By Supersled in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-27-09, 10:35 PM
  2. Water in Hull - 94 GTX
    By 94silver in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-03-08, 12:18 AM
  3. water in hull
    By slvr bulit in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 08-16-08, 09:02 PM
  4. Water in the hull
    By xl8luvr in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-29-07, 01:03 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
