Fuel pump 2005 RXP - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 10 of 10
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Mar 2009
    Location
    USA
    Posts
    27
    Watercrafts
    seadoo RXP 2005
    Thumbs Up
    Received: 0 Given: 0
    Default Fuel pump 2005 RXP
    Hi Everyone, How can I check if the fuel pump of my 2005 RXP is working properly. Because when I removed the fuel pump out of the gas tank, I noticed that the fuel pump will only work for 2 seconds and than shuts off. I wounder if this is normal. Thanks in advance for for input.
    0 Not allowed!
  2. # ADS
  3. #2
    seadoosnipe's Avatar
    Join Date
    Sep 2007
    Location
    Deep South
    Posts
    9,851
    Watercrafts
    1997 Challenger, 1997 GTX , 1991 SP and a shop with 2 spare 787cc's and a bunch of parts laying arou
    Thumbs Up
    Received: 78 Given: 0
    Default Normal....
    Yes, when you put the lanyard cap on, the fuel pump is suppose to run for 2 seconds (to prime system) then shut off till the engine gets a run from the ignition system through the engine management............
    Looking for tips and advice, researched articles on carbs, spark plugs and general maintenance can be found at Snipes Korner. You can also follow me on "Twitter".
    Quality parts at low prices, visit Seadoowarehouse right here in our own forum. Please PM me if you are having a problem finding what you need!
    Is your jet ski fast? Do you want your XP or RXP to stand out? I know a place that has what you need to make it faster. Make your jetsksi a muscle craft, not just the ordinary, standard stock ski.
    Seen my GTX?... Those awesome graphics can be purchased from JetSki Detailing. Tell them Seadooforum sent you.
    Ever wonder what the inside of your 787cc engine looks like. Want to identify the parts, check out my thread on the 787. I'm sure there is something for everyone who want to learn about the internal parts.
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Mar 2009
    Location
    USA
    Posts
    27
    Watercrafts
    seadoo RXP 2005
    Thumbs Up
    Default
    Thanks for your input Seadoosnipes, Tomorrow I will clean the fuel pump and install it back to see if the engine will fire up. According to my knowledge, it seems like the engine shuts off due to the lack of fuel.
    0 Not allowed!
  5. #4
    Junior Member Jetson's Avatar
    Join Date
    Jul 2009
    Location
    Cape Cod, MA
    Posts
    14
    Watercrafts
    2005 SeaDoo 4-Tech Sportster SCIC 215HP 2 kayaks and a canoe
    Thumbs Up
    Default results
    keep it posted...how did it go?
    0 Not allowed!
  6. ☑ ORIGINAL POSTER #5
    Junior Member
    Join Date
    Mar 2009
    Location
    USA
    Posts
    27
    Watercrafts
    seadoo RXP 2005
    Thumbs Up
    Default
    The fuel pump was working as it should, but the tank was full off debris (gum)which in turn was plugging the fuel line and shuts off the engine due to defeciency of fuel. After I cleaned the fuel tank entirely I never had any problem with shutting off of the engine. Hope to informed you accordingly.
    0 Not allowed!
  7. #6
    Junior Member woodpawn's Avatar
    Join Date
    Oct 2010
    Location
    florida
    Posts
    5
    Watercrafts
    98 XP 951 Modified 97 XP 800 Bored .50 97 GTX 800
    Thumbs Up
    Default
    my 2006 rxp will not pump fuel. i replaced the pump with another one but still won't pump fuel. it is coming on for about 5-10 sec but no fuel. tank is clean and has fuel in it. two different pumps same problem. any suggestions? thanks
    0 Not allowed!
  8. #7
    Join Date
    Oct 2010
    Location
    florida
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    has anyone had this problem before or know of something else to check. thanks
    0 Not allowed!
  9. #8
    SeadooForum Pro Michael211_2000's Avatar
    Join Date
    Sep 2010
    Location
    Splendora, Texas
    Posts
    1,312
    Watercrafts
    1975 Sidewinder of Wisconsin (jetboat) 2006 Seadoo RXT (PWC)
    Thumbs Up
    Received: 7 Given: 10
    Default
    Need more info.... how do you know it isn't pumping fuel? What are the symptoms and what have you checked already?
    If there's literrally no fuel in the fuel line, then something has to be stopped up at the pump. The pump is only supposed to come on for a few seconds initially to pressurize the fuel system... have you verified there is fuel in the line and it's under pressure?
    The odds of 2 fuel pumps in a row being bad is pretty slim. Something else is going on.
    - Michael
    0 Not allowed!
  10. #9
    Join Date
    Oct 2010
    Location
    florida
    Posts
    5
    Watercrafts
    Thumbs Up
    Default
    Quote Originally Posted by Michael211_2000 View Post
    - Michael
    Both pumps had different problems. The original pump was clogged up due to the internal sock screen. The second pump that I tried didn't work either due to the pickup tube being cracked and could not hold the pressure. I fixed the original pump and all is well. It runs perfect. Thanks for you reply.
    0 Not allowed!
  11. #10
    Join Date
    Sep 2010
    Location
    Splendora, Texas
    Posts
    1,312
    Watercrafts
    Thumbs Up
    Default
    Well I'll be darned... what're the odds that they both had problems? LOL! Glad to hear you finally got things straightened out though!!!!
    - Michael
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Used fuel pump
    By livi712002 in forum Non-Seadoo PWC Talk
    Last Post: 05-12-09, 11:11 AM
  2. RXT Fuel pump
    By breme in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 12-24-08, 05:14 PM
  3. 2005 RXP Jet Pump Oil--HELP!!
    By dharrison0001 in forum 4-Tec Sea-Doo PWC Forum
    Last Post: 10-04-08, 06:55 PM
  4. fuel pump??
    By gfgehring@comcast.net in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 09-15-08, 10:09 PM
  5. 97 gti fuel pump
    By brian1987 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-11-08, 03:15 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
