rotax 532 - Seadoo Forums
15% off Hydro Turf 10% off WSM Parts Email Sales@PWCMuscle.com
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 6 of 6
Thread: rotax 532
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Sep 2007
    Location
    ny
    Posts
    11
    Thumbs Up
    Received: 0 Given: 0
    Default rotax 532
    Need some help, I have a rotax 532 that i got from someone else that had the engine rebuilt. The engine runs good from idle to about 3/4 throttle, then it starts to bog down and sounds like it is skipping. I have changed the coil and cdi box on the side of the engine and still no help. Carbs are cleaned and been adjusted in every way. If the timing was off or the rotary valve was not set right would it cause this problem? This engine is mounted in my hovercraft but I wanted to get some info off this forum. Anyone have some ideas?
    Thanks,
    Bill
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    What are you using for an electrical box...Usually they require the stock MPEM,(Multi Purpose Electronic Control Module). It controls all the functions of the engine from starting, to rev limiter. If you using something different, I'd be lost.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Sep 2007
    Location
    ny
    Posts
    11
    Thumbs Up
    Default
    karl,
    It is the box that came with the engine.
    0 Not allowed!
  5. #4
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Posts
    11,229
    Watercrafts
    Thumbs Up
    Default
    It could be as in most seadoo's it contains the regulator/ rectifier, starter solinoid relay, and most appliciable fuses needed to power your seadoo...but being you have something kinda custom, your guess is as good as mine.
    Karl
    0 Not allowed!
  6. #5
    Chester's Avatar
    Join Date
    Nov 2008
    Location
    Surrey, BC Canada
    Posts
    1,198
    Watercrafts
    98 SXi Pro
    Thumbs Up
    Received: 7 Given: 4
    Default
    Have you replaced the points & condenser lately? Also, clean the carb.
    Chester
    "A smooth sea never made a skillful mariner."
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Junior Member
    Join Date
    Sep 2007
    Location
    ny
    Posts
    11
    Thumbs Up
    Default
    carbs are all cleaned, engine is electronic ignition, does not have points.
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. Seadoo GTS 720 Rotax Oil
    By gray in forum Non-Seadoo PWC Talk
    Last Post: 09-24-08, 09:01 AM
  2. 99/GTS 720 Rotax Oil type
    By gray in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 09-12-08, 05:12 PM
  3. 787 rotax engine
    By dad2ian96 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-08-08, 08:57 PM
  4. rotax won't run
    By mspt11 in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 07-07-08, 01:10 AM
  5. Replies: 0
    Last Post: 06-12-07, 11:49 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
