'96 seadoo XP de-winterzation help... - Seadoo Forums
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 7 of 7
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Jul 2008
    Location
    connecticut
    Posts
    20
    Watercrafts
    1996 seadoo xp
    Thumbs Up
    Received: 0 Given: 0
    Default '96 seadoo XP de-winterzation help...
    unfortunately last summer i was unable to winterize my 1996 seadoo XP at the end of the season due to a broken leg... just my luck right... so now i am just getting ready to get the ski ready for the summer and i'm planning on having my work cut out for me. the last thing i did to the ski was run it without water for 30 sec or so to empty out whatever water i could. then i placed the ski in back of my garage under a tarp for the winter. now that i'm all healthy again i'm looking for some advice as to where i should start in tackling this job... any help will be greatly appreciated! thanks in advance and if you need any clarification let me know.. i'm happy to help.
    thanks again-- jon
    0 Not allowed!
  2. # ADS
  3. #2
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Sunny S.W. coast of Englewood, Florida
    Posts
    11,229
    Watercrafts
    1996 Chris Craft 26' Cruiser, Kawasaki 440 Superstock, 550 Mod., 2008 200Speedster 310 Hp
    Thumbs Up
    Received: 16 Given: 0
    Default
    Jon, first thing is get the battery fully charged up. Have it Load tested at like Auto Zone too after you get it charged to see if it has any bad cells. If it's bad, replace it. I would squirt some wd-40 down each cylinder, Add some fresh spark plugs. If the gas smells bad I would try to siphon out as much as you can, and add some fresh fuel. Check all the nuts and bolts for tightness and look everything over to see if all is ok. Fill up the injector oil. Grease the Impeller shaft fitting behind the engine. Spray the impeller assy with wd-40 and check the clearance too. If the carbs appear to look gummy, they might need to be removed and cleaned, but see if it fires up first. Give the seadoo a good cleaning and add the battery and fire it up on the hose like normal. Let it run for a few minutes. If all is good, go have some fun.
    Karl
    Please, If you have a "troubleshooting" request, use the correct category in the Sea-Doo Forum first.
    "Premium / Subscribed Members", not getting an answer, pm me directly for Expert Advise.
    When your ready for more performance, click on the this link!
    Click to order your Sea-Doo Parts at a fair price.
    Click here to view/join our Group on "Face Book"
    0 Not allowed!
  4. ☑ ORIGINAL POSTER #3
    Junior Member
    Join Date
    Jul 2008
    Location
    connecticut
    Posts
    20
    Watercrafts
    1996 seadoo xp
    Thumbs Up
    Default
    karl- thanks for the help its greatly appreciated... i'm going to get on that this weekend hopefully... btw i forgot to mention that i converted it to premix fuel. will that make a difference?
    0 Not allowed!
  5. #4
    kustomkarl's Avatar
    Join Date
    Sep 2007
    Location
    Posts
    11,229
    Watercrafts
    Thumbs Up
    Default
    Just be sure you use the same oil as the original owner...premix should be 40:1. Leave the oil injector tank in place with the oil lines to the bottom of the engine to lube the rotary valve. Why Change the oil injector...it will use lots of oil now and foul plugs. The injector is a Variable rate injector system. It injects oil at different rates depending on rpm. Not a steady amount at all rpms as pre mix does.
    Karl
    0 Not allowed!
  6. #5
    Experienced Rider b15philly's Avatar
    Join Date
    Nov 2008
    Location
    Connecticut
    Posts
    468
    Watercrafts
    1996 SEADOO GSX NOT STOCK, 2000 XPL STOCK
    Thumbs Up
    Default
    Hey John ware abouts in CT do you live, Im in the Windham area if you ever looking for someone to ride with
    0 Not allowed!
  7. ☑ ORIGINAL POSTER #6
    Junior Member
    Join Date
    Jul 2008
    Location
    connecticut
    Posts
    20
    Watercrafts
    1996 seadoo xp
    Thumbs Up
    Default
    i'm out of waterford... as long as i get everything up and going i'll be happy too...
    karl- i removed the pump shaft because the ski sat for a while and i was unsure as to whether or not the oiler was working. when i began the pjct of putting it back together again i didnt want to risk not having an oils supply reach the engine..i i just decided it was best to be daft rather than sorry..... i held on to the shaft and left the lines in tack so at any given moment i may decide to put it back in...
    0 Not allowed!
  8. #7
    Junior Member
    Join Date
    Nov 2012
    Location
    Indiana
    Posts
    1
    Watercrafts
    2006 Sea-Doo GTX
    Thumbs Up
    Default
    Sorry to piggyback on condo180's thread, but it appears that I'm not allowed to create a new thread.
    In a sticky thread that is now closed, it was written:
    "16. On the supercharged, intercooled models, the exhaust system is self draining but the intercooler and manifold need to the following protection."
    That thread doesn't specifically address the non-supercharged models relating to water/anti-freeze, so I'm wanting to be sure I understand correctly that non-supercharged models are also self draining. In other words, no anti-freeze needed. I have a 2006 GTX 4-stroke.
    Thanks for any help you can provide!
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
