utopia 4500 rpm max no top end - Seadoo Forums
Visit PWCMuscle.com
for 15% off all Hydro Turf - CODE: HYDRO15
Need OEM parts for your boat or PWC? Visit SeadooWarehouse.com
Results 1 to 2 of 2
  1. ☑ ORIGINAL POSTER #1
    Junior Member
    Join Date
    Oct 2008
    Location
    Tampa
    Posts
    4
    Watercrafts
    2003 Utopia 185 Merc 210 M2
    Thumbs Up
    Received: 0 Given: 0
    Default utopia 4500 rpm max no top end
    I have a 2003 Utopia 185 with the 210 m2 from Merc. Normal top end is 55MPH @ 5600 RPMs. Revs on hose to top end 5700 but when in water only gets to 4500. It used to jump out of the water and fully plain in5 seconds and accelrated to 55 MPH in 12 t0 15 seconds. I have replaced Fuel, Fuel Filter and Plugs. this Boat was an fine last time it was out (Labor Day).
    I originally thought I purchase some bad fuel because I tanked up after the Labor Day outing, I have replace with new gas.
    I've rebuilt the fuel pump this week and still the same when I tested it today.
    Any ideas on where to go next?
    I have the both Utopia parts / service manual and the Merc M2 service manual so I can keep up with the next step.
    0 Not allowed!
  2. # ADS
  3. #2
    rookie101's Avatar
    Join Date
    Jun 2008
    Location
    Okotoks Alberta, Canada
    Posts
    1,012
    Watercrafts
    2006 Yamaha AR230 HO 320hp
    Thumbs Up
    Received: 4 Given: 0
    Default
    Check to make sure you are getting wide open throttle, and your cable is adjusted properly. Also my 200dfi has an air filter in the plastic engine cover, if yours is equipped with the same filter, make sure it is clean and the air intake is not plugged.
    When the engine is at 4500 rpm does it seem nice and smooth, or is there a miss or noticeable shake? If it feels like there is a miss, you may have a plug wire, or coil that is breaking down under load.
    Aaron
    0 Not allowed!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. 98 gtx rfi misses between idle and 4500 rpm
    By eparker in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 01-07-09, 07:20 AM
  2. Utopia 185 won't exceed 4500 RPMs
    By joneil226 in forum Mercury Powered SeaDoo Sport Boats
    Last Post: 10-12-08, 08:40 PM
  3. 2002 GTX DI - 4500 rpm max
    By c-doo in forum 2-Stroke Sea-Doo PWC forum
    Last Post: 05-16-08, 10:37 PM
  4. Engine stalls when i get to 4500 rpms
    By tinman37 in forum 2-Stroke SeaDoo Sport Boat Forum
    Last Post: 05-12-08, 05:10 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Register forum what's new
